Hi,
I have been chasing a slow leak on my daughters cruisr for a year and its finally reached the point where it is losing freon overnight to a day and half. I put gages on it today and found the system sitting zero charge. Put a vacuum pump on the system and pulled it down to -28 in hg and let it set, lost 4 inches in 5 minutes. tells me that its a pretty significant leak. Since it has been a progressively faster leak rate, I am thinking possibly ac compressor seal or lesser possibility evaporator? Anybody have any experience with this problem and what the most common failures are regarding the ac?
04 PT Cruiser Turbo 5 speed, 96,450 miles.
Thanks for assist.
regards,
doc
