Disc Brake Conversion Kits #66759
05/31/08 05:03 PM
05/31/08 05:03 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Ok I am sure this has been discussed many times, but I am considering changing my four wheel 11" power drum car to either disc up front or disc all around.
With so many kits on the market I am looking for feedback on what to go for and what to avoid. Some come complete with spindles and some use stock drum spindles. Currently I am looking at kits from Master Power and the Right Stuff. Any feed back will be appreciated.
[image]https://board.moparts.org/ubbthreads/upload2/5353101-YoungGunChallengerNats.jpg[image] My 70 Dodge Challenger R/T SE 383 Magnum, 727, A/C, Cruise, Six-way seat.
Re: Disc Brake Conversion Kits [Re: faud88] #66760
06/02/08 06:06 PM
06/02/08 06:06 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
btt
Re: Disc Brake Conversion Kits [Re: faud88] #66761
06/02/08 06:31 PM
06/02/08 06:31 PM
P
Pauls69 Offline
super gas
Pauls69  Offline
super gas
P
well, i'll put in my $0.02.
i got the master power kit in my car.
the positives:
the kit was complete
it supposedly uses all factory hardware, so you should be able to get new pads @ the local parts store
the not-so positives:
imo, tech support was difficult to contact or get a return phone call.
the kit only offers 10.75" rotors
if i had to do it over again, i'd do the f/m/j body setup here & get 11.75" rotors for (probably) less $$$:
http://www.bigblockdart.com/techpages/dbconversion.shtml
you could also contact dr diff, who has conversion kits available:
http://members.aol.com/doctordiff/
Re: Disc Brake Conversion Kits [Re: Pauls69] #66762
06/02/08 07:40 PM
06/02/08 07:40 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If you are looking for the FMJ spindles and big caliper brackets I might have a set available.
Re: Disc Brake Conversion Kits [Re: faud88] #66763
06/02/08 08:14 PM
06/02/08 08:14 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have AndyFs gen 1 Viper kit on my Challenger. If you can get a good set of used calipers at a decent price it is a great setup for the money.
DrDiff has a kit that I have heard good things about also. I think he uses the Cobra caliper.
Re: Disc Brake Conversion Kits [Re: faud88] #66764
06/02/08 09:33 PM
06/02/08 09:33 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I am looking at the stainless steel brakes set up,looks good,4 piston calipers and complete bolt on.Anybody have an opinion on those?????
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
