Help!!! serious vibration
#667554
04/11/10 10:20 PM
04/11/10 10:20 PM
Posts: 710 Harrisburg Pa. 17112
moparmikethree
1970 Challenger , 360, 727 , 8 3/4
When going down the road , bad vibration at 45mph and up. When putting in neutral , almost all goes away. Engine in neutral is very smooth. (all rpm's)
Trans is rebuilt, with weighted torque converter. New trans mount. Drive shaft is balanced and new u-joints.
When unbolting driveshaft and pushing completely into trans , how much space should be at rear u-joint and rear yoke?
How can I tell if it is in the Rear end itself, bent axle, or if it is inside the trans??
Please help, Thanks Mike
Re: Help!!! serious vibration
[Re: moparmikethree]
#667558
04/11/10 10:29 PM
04/11/10 10:29 PM
RapidRobert
w the common flat aftermarker rear ext housing seal, 3/4". EDIT did the vibration start all of a sudden? Any part changes/adjustments right before it started? Does it change better or worse going from accel to decell or vice versa?
#667561
04/11/10 10:52 PM
04/11/10 10:52 PM
RapidRobert
After the swap was it OK then it developed? W the trans mount/bolts good I'd open up the ujoints & check for any needle problems/looseness anywhere.
#667565
04/11/10 11:40 PM
04/11/10 11:40 PM
RapidRobert
Mike has it vibrated like this ever since the swap? My money is still on the driveshaft (angles/ujoints). On my 65 dart 318/904 I used a driveshaft that was too short and the yoke did not engage the tranny splines enough (way more than 3/4") and you could feel the play of the yoke on the splines as you slid it in and it vibrated mostly on decell but nothing like yours is. I found the correct shaft that was less than an inch longer & that solved it
