Help!!! serious vibration #667554
04/11/10 10:20 PM
04/11/10 10:20 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
1970 Challenger , 360, 727 , 8 3/4
When going down the road , bad vibration at 45mph
and up. When putting in neutral , almost all goes away. Engine in neutral is very smooth. (all rpm's)
Trans is rebuilt, with weighted torque converter.
New trans mount. Drive shaft is balanced and new u-joints.
When unbolting driveshaft and pushing completely into trans , how much space should be at rear u-joint and rear yoke?
How can I tell if it is in the Rear end itself, bent axle, or if it is inside the trans??
Please help, Thanks Mike
Re: Help!!! serious vibration [Re: moparmikethree] #667555
04/11/10 10:22 PM
04/11/10 10:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What are your driveline angles?
Re: Help!!! serious vibration [Re: NITROUSN] #667556
04/11/10 10:26 PM
04/11/10 10:26 PM
Its been awhile since I checked them, If I recall it is 1 1/2 degrees down on rear end and 1 1/2 degrees up on trans. Not entirely sure but thats what I recall
Re: Help!!! serious vibration [Re: moparmikethree] #667557
04/11/10 10:28 PM
04/11/10 10:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Re: Help!!! serious vibration [Re: moparmikethree] #667558
04/11/10 10:29 PM
04/11/10 10:29 PM
w the common flat aftermarker rear ext housing seal, 3/4". EDIT did the vibration start all of a sudden? Any part changes/adjustments right before it started? Does it change better or worse going from accel to decell or vice versa?
Re: Help!!! serious vibration [Re: RapidRobert] #667559
04/11/10 10:41 PM
04/11/10 10:41 PM
This car was an original slant six/ 904, Converted over to a 360, 727, everything new (everything)
When accelerating it is really bad. Feels like a tremor starting at the firewall and traveling under the console the whole way back to the rear
Vibration gets better when slowing down
Re: Help!!! serious vibration [Re: moparmikethree] #667560
04/11/10 10:45 PM
04/11/10 10:45 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Sounds like incorrect pinion angle.
Re: Help!!! serious vibration [Re: moparmikethree] #667561
04/11/10 10:52 PM
04/11/10 10:52 PM
After the swap was it OK then it developed? W the trans mount/bolts good I'd open up the ujoints & check for any needle problems/looseness anywhere.
Re: Help!!! serious vibration [Re: moparmikethree] #667562
04/11/10 10:59 PM
04/11/10 10:59 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
Are the balance weights missing from the torque converter? Check the U-joints to see if they are centered in the yokes, if they are not they will bind and cause a bad vibration.
Re: Help!!! serious vibration [Re: Mopar1] #667563
04/11/10 11:16 PM
04/11/10 11:16 PM
All u-joints are new, but I rechecked them, all needles are good , and u-joints are greased.
torque converter does have the weight on
Re: Help!!! serious vibration [Re: RapidRobert] #667564
04/11/10 11:18 PM
04/11/10 11:18 PM
when you disconnect the driveshaft and push completely in how much distance to the rear yoke?
Re: Help!!! serious vibration [Re: moparmikethree] #667565
04/11/10 11:40 PM
04/11/10 11:40 PM
Mike has it vibrated like this ever since the swap? My money is still on the driveshaft (angles/ujoints). On my 65 dart 318/904 I used a driveshaft that was too short and the yoke did not engage the tranny splines enough (way more than 3/4") and you could feel the play of the yoke on the splines as you slid it in and it vibrated mostly on decell but nothing like yours is. I found the correct shaft that was less than an inch longer & that solved it
Re: Help!!! serious vibration [Re: RapidRobert] #667566
04/13/10 01:55 PM
04/13/10 01:55 PM
Checked pinion angles with suspension loaded
as driving down road
Drive shaft angle is -2 degrees down towards rear
output shaft of trans is at 0 degrees
Rear end at flange is -3 degrees.
What is needed, do I have to lift the trans?
or change the rear end?
Re: Help!!! serious vibration [Re: moparmikethree] #667567
04/13/10 01:56 PM
04/13/10 01:56 PM
It has been there ever since the swap.
I had the tires road force balanced
Re: Help!!! serious vibration [Re: moparmikethree] #667568
04/13/10 03:11 PM
04/13/10 03:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I've seen the weights come of the torque.
check and see if the u joints stayed centered may a clip is off??
Re: Help!!! serious vibration [Re: Dodgem] #667569
04/13/10 03:22 PM
04/13/10 03:22 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I had a similar problem with similar symptoms on my Challenger. Turns out that my brand new, and supposedly balanced driveshaft wasn't balanced at all...
Re: Help!!! serious vibration [Re: Dodgem] #667570
04/13/10 10:41 PM
04/13/10 10:41 PM
weights are still on the torque,
What about the readings for the pinion angle
