Re: Aeromotive Fuel Pressure Issues? LONG [Re: fullmetaljacket] #667378
04/12/10 11:02 PM
04/12/10 11:02 PM
Missouri
galen Offline
galen  Offline
Missouri
I have rock steady pressure with the A1000. With 900 miles so far. I am running before and after filters with #10 supply to the fuel log, #10 from log to regulator, and #10 return back to tank,and good tank vent. This is how aeromotive had me plumb it.
Re: Aeromotive Fuel Pressure Issues? LONG [Re: galen] #667379
04/13/10 08:13 AM
04/13/10 08:13 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I've got the same crazy stuff going on, but with Mallory 140 pump. I've tried both of my pumps and a brand new regulator, and all new lines from front to back. Even have different carb on it now. Same thing!
Preasure can be fine one moment and next it is low, or high. Set the regulator, and then it will be different again, in 5 minutes. Not just a pound or so, but 2 or 3 pounds different. And no, it's not the guage!!!!! Guage is mounted 4 feet from the engine, where I can see it, too.
I'll try my holley blue pump next....maybe my mallory pumps are just worn out?
I give up!
Re: Aeromotive Fuel Pressure Issues? LONG [Re: galen] #667380
04/13/10 08:15 AM
04/13/10 08:15 AM
LAR_414 Offline
LAR_414  Offline
Maybe this is the new "my cam just wiped out" issue. Seems like a lot of people are, all of a sudden, having similar problems. Maybe something new is in the fuel that we put in the cars, like when they took a lot of zinc / phos out of the oil!
Re: Aeromotive Fuel Pressure Issues? LONG [Re: LAR_414] #667381
04/13/10 09:11 AM
04/13/10 09:11 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I've seen this (not on my setup) It was stuff in the system, debris was from old fuel cell foam breaking down. HTH's
Re: Aeromotive Fuel Pressure Issues? LONG [Re: LAR_414] #667382
04/13/10 09:29 AM
04/13/10 09:29 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I give up!
I'm betting cavition, gas is very hard to suck and pump and changes with temperture. Most installations don't have a large enough inlet line or are configured wrong to insure against cavition. My
Re: Aeromotive Fuel Pressure Issues? LONG [Re: RyanJ] #667383
04/13/10 09:30 AM
04/13/10 09:30 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
10-micron filter before the pump is too small, it'll lead to cavitation.
100-micron before the pump, 10-micron after.
Don't ask me how I know.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Aeromotive Fuel Pressure Issues? LONG [Re: Tig] #667384
04/13/10 09:31 AM
04/13/10 09:31 AM
Arizona
Chris'sBarracuda Offline
Arizona
You might check to see if the vent is clogged. Just something from Aeromotive website.
Also here is something else that Aeromotive discusses in one of their Tech bulletins.
http://aeromotiveinc.com/2010/01/fuel-filtration/
They frown on pre pump filters. I know that when Kyle was there he told me NOT to use any filter before the pump. I filter the fuel as I put it in the tank. I have the A-2000 pump set @ 25 psi at the pump bypass, then regulate it down with the A-4 regulator.
HTH's..
Chris...
Re: Aeromotive Fuel Pressure Issues? LONG [Re: Chris'sBarracuda] #667385
04/13/10 09:36 AM
04/13/10 09:36 AM
Cincinnati, Ohio
Cincinnati, Ohio
HTH's..
Chris...
Pretty much what I have been saying, no filter before the fuel pump. Strain the fuel while adding to the fuel cell and never leave the cap off for long.
