only 4 " of Hg at idle? is this normal for this cam?
#66733
05/31/08 04:26 PM
05/31/08 04:26 PM
Posts: 1,663 E.Amherst, NY
69RR
E.Amherst, NY
I've got a .557 cam and I'm trying to tune it on a 440 (with a six pack). The most I can get is 4" at idle. I've tried to tune it messing with the timing and mixture screws but no luck. I'm just wondering if this normal for this cam - I don't have the specs for it. My .509 could pull 11-12" inches this has me puzzled.
Dean
Got my hands on the wheel, foot to the pedal, gonna drive this car till the tires turn to metal - gonna sleep when I'm dead and laugh at the devil..
Re: only 4 " of Hg at idle? is this normal for this cam?
[Re: 69RR]
#66734
05/31/08 04:54 PM
05/31/08 04:54 PM
Posts: 614 Id
mopeman
Id
Sounds about right, how did you get 11-12" with a .509? I get get about 6" with my old school MP .509.
Mopar or no car MoPar=Massivly Over Powered And Respected!
'93 W250 Ram '68 Charger '67 Coronet 500 my steet/strip rod-now a 6BBL!
[Re: Joshs68]
#66738
06/02/08 07:08 PM
06/02/08 07:08 PM
Posts: 1,261 ILL
mark7171
ILL
i got around 7"-8" vacuum with a 440" a 509 cam and a 1200rpm idle.
that is a great cam. when you do the whole mopar performance bracket package suggestion, its makes the numbers it claims.
------ other vac readings to compare, will vary-----
i got 10" or so with the chevy sbc 350 Edelbrock RPM package.
12-14" with a xe268 sbc 350 at 900 rpm idle
19-20" with the 340 mp cam in 318"
[Re: mark7171]
#66739
06/02/08 10:19 PM
06/02/08 10:19 PM
69RR
E.Amherst, NY
The car runs good I'm just surprised how low the vacuum can go. I'm running rich but I may have a power valve issue - I'll have to look it may have a 6.5 pv., would a 2.5 be better consider the vacuum issue? Mpg is bad - around 8mpg when I don't get on it maybe worse - hard to tell 'cause I can't keep my foot out of it. Went thru 30 bucks of gas (4.39 a gallon) just testing it around the neighborhood maybe a total of 10 miles - not too good.
Dean
[Re: 69RR]
#66740
06/02/08 10:24 PM
06/02/08 10:24 PM
normal? nope. verify your vacuum gauge is accurate. if it is, then start going over the carb settings again.
[Re: 69RR]
#66742
06/02/08 10:32 PM
06/02/08 10:32 PM
8-10Hg. check the lash/timing/carb/engine sealing/ etc.
powervalves? vac(in gear)/2+.5=PV requirement. don't base it on the vac. you have now.
#66744
06/02/08 10:35 PM
06/02/08 10:35 PM
69RR
E.Amherst, NY
Thanks guys - may have check the lash on this one...
Dean
