Enigine ping
#667260
04/11/10 07:54 PM
04/11/10 07:54 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Hey guys !! Got the new 408 engine in the car today, the engine hasn't run yet, but out of curiosity, I gave it a couple of turns just to see the cylinder pressure with a Equus pressure tester.
Cylinder pressure reads 195 lbs with RHS MA-X iron heads......I am very much afraid of pre ignition or pīng !!.....So is this really too much to run on premium gas or is it borderline ?
Also, what are the basics to prevent pre ignition in an engine ?
Dan
Re: Enigine ping
[Re: Wedgeman]
#667261
04/11/10 09:04 PM
04/11/10 09:04 PM
RapidRobert
So is this really too much to run on premium gas or is it borderline?
too high. I'd fill it w race gas for the breakin then scale the proportion afterwards.You sure dont need any pinging on breakin to cause havoc w your investment.EDIT or several gallons of race gas in a container hooked to the pump inlet for the breakin
Re: Engine ping
[Re: ahy]
#667265
04/12/10 08:00 PM
04/12/10 08:00 PM
Posts: 1,261 ILL
mark7171
ILL
Was the carb off/not installed, when you did the test? or was it at wide open throttle.
Have seen higher numbers when the throttle plates were shut.
195 is too high. try B and P 94oct with a 5-10% pure toulene mix. Even without the mix it should light up and run breakin with no load. Unless your timming is all goofy.
