Steering column #667104
04/11/10 06:30 PM
04/11/10 06:30 PM
S.E. Wis
a4runer Offline OP
a4runer  Offline OP
S.E. Wis
Took my RR steering column partial apart to paint it today and when reassembled it no longer has any detents when moving the shifter. Nothing fell out,bowls tighten up together, spring is still in lower bowl behind the shifter but no detents anymore.Anybody learned the hard way how to put it back the right way and could pass that info along. Thanks Bruce....It' a '69
Re: Steering column [Re: a4runer] #667105
04/12/10 07:11 AM
04/12/10 07:11 AM
S.E. Wis
a4runer Offline OP
a4runer  Offline OP
S.E. Wis
Just a bumper for one more try for info... Thanks
Re: Steering column [Re: a4runer] #667106
04/12/10 09:06 AM
04/12/10 09:06 AM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
You won't feel the detents until it's hooked up to the trans. However you should have to pull the shifter toward you to move it out of park position even without it being hooked to the trans. If you have to do this I'd say it's OK.
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
