steel wheels question
#666963
04/11/10 04:04 PM
04/11/10 04:04 PM
Posts: 840 media, Pa
revcon
media, Pa
Can anyone tell me what steel wheels will fit on my 68 dart with the GM disc brake set up? large bolt pattern. Do Mopar 15x7 fit? Scott
68 dart 383/727/3.55
Re: steel wheels question
[Re: 69L78Nova]
#666965
04/11/10 08:56 PM
04/11/10 08:56 PM
revcon
media, Pa
Instead of paying through the nose for kelsey hayes parts, I bought an aftermarket set up that is comprised of GM parts, single piston, readily available etc. Problem is the mopar 14" wheels don't fit, so I am looking for 15's
[Re: revcon]
#666966
04/11/10 09:07 PM
04/11/10 09:07 PM
Posts: 1,443 Maryland
Dads426
Maryland
It doesn't matter which caliper you are using (although some might interfere with 14" rims); the rotor and bolt circle (BC) used on it will determine which rim. Early rotor with a 4" bolt circle may be hard to find a 15" rim; late model mopar rim with 4-1/2" BC will be easier; if you figured out how to mount a GM rotor, then I believe they run a 4-3/4" BC. Guy up between York and Baltimore made some custom rims for us (The Wheeler Dealer).
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
