The Super Charger store, how much are the kits ? #66695
05/31/08 02:46 PM
05/31/08 02:46 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm not really interested in doing it, but I just was wondering how much their procharger kits run...Any idea ? I don't want to call them and just ask for $ prices if I have no intent of buying.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: The Super Charger store, how much are the kits ? [Re: AlexP] #66696
05/31/08 03:25 PM
05/31/08 03:25 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Depending on options and head unit you go with $4 to $7K.
I priced out a F1 kit with the p/s kit and water inj and it was almost $5K if I remember correctly.
Re: The Super Charger store, how much are the kits ? [Re: AlexP] #66697
06/02/08 10:10 PM
06/02/08 10:10 PM
Mr440GSS Offline
Mr440GSS  Offline
$6K+, D1 head unit, P/S kit, water injection, carb, fuel pump and regulator, etc. Basically everything to do the swap except the fuel line itself. Did it last year, and yes, I recommend it....
Re: The Super Charger store, how much are the kits ? [Re: Mr440GSS] #66698
06/02/08 10:37 PM
06/02/08 10:37 PM
Ft Worth,Tx
71mopar383 Offline
super street
71mopar383  Offline
super street
Ft Worth,Tx
How much boost r u running? And what all did you do to the bottom end?
71 Charger
Re: The Super Charger store, how much are the kits ? [Re: 71mopar383] #66699
06/04/08 10:51 AM
06/04/08 10:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
did my own for around $2200 including pipe work, gauges, fuel system upgrades and sensors. It can be done cheaper if you have welding skills and can prep your own carb. 440 5.5-6psi netted almost a full second of et, totally drivable and a real kick in the pants.
Re: The Super Charger store, how much are the kits ? [Re: Mr440GSS] #66700
06/04/08 01:50 PM
06/04/08 01:50 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
What did you use for a fuel pump, and regulator. Are you using -8 lines?
It looks great!
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: The Super Charger store, how much are the kits ? [Re: Kam*Kuda] #66701
06/04/08 02:03 PM
06/04/08 02:03 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I ran 3/8 all the way. I used a Summit electric pump and ran it thru a Carter Street/Strip pump. You don't need both but you can pressurise the Mech unit. You eiither have pressurize the mech pump or use a regulator that can be pressurized. I ran the Mech pump for normal driving and turned on the electric for the track and when I was gettin' on it.
