What rear wheel BS to run ? #666942
04/11/10 02:21 PM
04/11/10 02:21 PM
The Wet Coast, Canada
megajoltman Offline OP
I will be buying rims in the near future for my mini tubed 69 Dart with a stock drummed Dana 60. I will run either a 10.5 or 12.5 tire. Still need to shorten the rear end so I am wondering which back space would be the best to use or does it really matter? I was thinking of 5.5 BS rim.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: What rear wheel BS to run ? [Re: megajoltman] #666943
04/11/10 04:18 PM
04/11/10 04:18 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
When i build cars i like to narrow the rear as much as possible fo less weight. My car uses 3" backspace on 12" wheels
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What rear wheel BS to run ? [Re: megajoltman] #666944
04/11/10 06:32 PM
04/11/10 06:32 PM
I would not buy rims until I had the rear end shortened and mounted permentaly. Are you going to use ladder bars, four link or leaf springs for the rear suspension? If leaf springs are you moving them into the frame or leaving them in the stock location? I have a 1969 Dart GTS that I raced for several years, I had the leaf springs move into the rear sub frames and used a set of 8.5 Centerline wheels with 4 7/8 offset with the stock width OEM A body 8 3/4 rear end. That car had the stock rear wheel tubs in it and had plenty of room from 29.5x105 x15 slicks on the inside edges to the stock wheel tubs and frame rails
