Lifter or exhaust leak? #666910
04/11/10 01:43 PM
04/11/10 01:43 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
Just broke in my new VooDoo cam with new lifters. It seems I have either a lifter/rocker noise or exhaust leak. the ticking is more of a dull tick not a real high pitched tick and it starts coming on at 2000 rpm and not before.
What should I start looking for?
Thanks.
Re: Lifter or exhaust leak? [Re: 74RR] #666911
04/11/10 01:47 PM
04/11/10 01:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Take off a valve cover and start the engine and with a hammer handle put pressure on the push rod end of the rocker arms. If it is a lifter or rocker noise it will quit when you hit the right one.
Or pour a little oil into the carb and the smoke will show up a leaky manifold or exhaust
Re: Lifter or exhaust leak? [Re: MoparforLife] #666912
04/11/10 01:55 PM
04/11/10 01:55 PM
74RR Offline OP
74RR  Offline OP
Cool. I like these ideas,simple and quick!
Re: Lifter or exhaust leak? [Re: 74RR] #666913
04/11/10 02:12 PM
04/11/10 02:12 PM
Upper Midwest
Upper Midwest
& messy.
Re: Lifter or exhaust leak? [Re: MoparforLife] #666914
04/11/10 04:06 PM
04/11/10 04:06 PM
74RR Offline OP
74RR  Offline OP
Messy is right! Everything checked out allright. Lifters are good AND I can't seem to find a exhaust leak anywhere.
I have to ask,what about a cam or main bearing? Would that make noise all the time or just at higher RPM's?
Re: Lifter or exhaust leak? [Re: 74RR] #666915
04/11/10 04:13 PM
04/11/10 04:13 PM
Is this a new rebuild or did you only change/breakin a new cam/lifters? I'm assuming new rebuild otherwise it'd point directly to the replaced parts especially the lifters
Re: Lifter or exhaust leak? [Re: RapidRobert] #666916
04/11/10 04:14 PM
04/11/10 04:14 PM
74RR Offline OP
74RR  Offline OP
Yep,new rebuild.
Re: Lifter or exhaust leak? [Re: 74RR] #666917
04/11/10 04:21 PM
04/11/10 04:21 PM
Upper Midwest
Upper Midwest
A main will loose oil pressure and rarely knock that is noticeable and when it does it is a dull rap. cam bearings will loose your pressure too and no noise. Fuel pump arm???
Re: Lifter or exhaust leak? [Re: MoparforLife] #666918
04/11/10 04:22 PM
04/11/10 04:22 PM
74RR Offline OP
74RR  Offline OP
Oil pressure is good.
Re: Lifter or exhaust leak? [Re: 74RR] #666919
04/11/10 07:37 PM
04/11/10 07:37 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
does it go away on coast? if so, it's an exhaust leak.
2017 Grand Cherokee Overland
Re: Lifter or exhaust leak? [Re: patrick] #666920
04/12/10 07:02 AM
04/12/10 07:02 AM
74RR Offline OP
74RR  Offline OP
I'll check that tonight after work,thanks.
Re: Lifter or exhaust leak? [Re: 74RR] #666921
04/12/10 08:09 AM
04/12/10 08:09 AM
scratchnfotraction Offline
I dont think I have ever had a lifter tick,I have chased them for yrs though
allways an exhast leak on my junk
holes in the floor make it sound like a lifter tic
Re: Lifter or exhaust leak? [Re: 74RR] #666922
04/12/10 08:22 AM
04/12/10 08:22 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I had the same dilemma, I used a piece of 3/8" rubber fuel line as a stethoscope and was able to pin point the exhaust leak in minutes. Some of the best advise I recieved here on Moparts.
Re: Lifter or exhaust leak? [Re: patrick] #666923
04/12/10 08:09 PM
04/12/10 08:09 PM
74RR Offline OP
74RR  Offline OP
Ok I went out for a run and like I mentioned earlier the tick comes on at about 2000 and I noticed it changes pitch just a little bit. When I let of the gas the sounds does go away as far as I could tell. Tomorrow I'll start checking header gaskets and the collector gaskets too.
Thanks for everyones replys!
Re: Lifter or exhaust leak? [Re: 74RR] #666924
04/12/10 09:09 PM
04/12/10 09:09 PM
if running headers,dont over look some of the factory welds and the 4 into 1 colletor
I have found a bunch of header will leak there..i only use cheap ones though
also look them over good for cracks in the "whole length" of each tube
with most flat mannys to head seal I use the copper rtv over the gaskets that come in whole engine kits (let cure over night)
also do this on bad/warped header flanges to head with header gaskets ( results will vary )
now mine does have a heck of a clatter that is the lifters till the oil hits it some times on start up...but can hear it clearly...
after running you only hear it in the cab
been chasing it for a long time on mine with some worn out engines over the yrs
Re: Lifter or exhaust leak? [Re: scratchnfotraction] #666925
04/13/10 10:21 AM
04/13/10 10:21 AM
74RR Offline OP
74RR  Offline OP
I'm running cheap headers myself. One more thing I can look at.
