Indy EZ295 valve train- swap to Harland Sharp Questions #666897
04/11/10 12:56 PM
04/11/10 12:56 PM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
I have searched and have not located the information i am looking for. So, here it goes.
Running the Indy supplied black 1.5 aluminum rockers and shafts on my Indy Little EZ 295 cnc heads. I want to switch to Harland Sharp 1.5's and am curious as to the difference in pushrod length. I assume that if nothing else is changed that the difference between pushrod length would be pretty constant. Anyone have any info on this?
Re: Indy EZ295 valve train- swap to Harland Sharp Questions [Re: Plumcrazyracing] #666898
04/11/10 03:19 PM
04/11/10 03:19 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
just buy the harlands and see if its the same or just use a pushrod checker when you set it all up
Mopar Performance
Re: Indy EZ295 valve train- swap to Harland Sharp Questions [Re: Plumcrazyracing] #666899
04/11/10 09:39 PM
04/11/10 09:39 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... I assume that if nothing else is changed that the difference between pushrod length would be pretty constant. Anyone have any info on this?
Yeah, don't assume anything. One of the big differences I've found between various rocker arm brands is where they locate the adjusting screw. If you can swap brands and your old pushrods are actually the correct length for new rockers, consider yourself lucky.
