Will F body pedals fit an A body #666877
04/11/10 12:18 PM
04/11/10 12:18 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I know F body transmissions will fit an A body but will the 4 speed pedals also fit?
Re: Will F body pedals fit an A body [Re: Dart6pak] #666878
04/11/10 12:23 PM
04/11/10 12:23 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
You could probably make them fit, but they won't just bolt in. The support that the column bolts to is different as is the linkage for the brake pushrod.
A body pedals are pretty easy to find so I just go that route.
