Houston we have a problem... Found Problem
#666850
04/11/10 11:55 AM
04/11/10 11:55 AM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Ok guys, I need to pick your brains. Took car out yesterday, car went 5.70 first pass, then 5.676 , then 5.78 and 5.83, 5.961 .60'fts were 1.30 1.295 1.359 1.379 and 1.417 had to abort run car got loose and went to the guard rail. Noticed upper and lower radiator hose balloning up. Water temp never getting above 180 on gauge. We ran compession check all cylinders 220 except #3 at 200. id we blow a head gasket? Popped the rad cap off temp was 100 and it shot water cause oif pressure. fill rad and ran motor without cap and water was doing like seltzer water. fizzling and dancing. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Houston we have a problem...
[Re: Mopar_racer_99]
#666851
04/11/10 12:00 PM
04/11/10 12:00 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Time for a leakdown test. It will give you a better state of what is going on in the engine. Ring seal, head gasket seal, guides etc..Sounds like oyu are getting some leakage past the hg to me.
Post deleted by Defbob
[Re: Al_Alguire]
#666852
04/11/10 12:17 PM
04/11/10 12:17 PM
#666853
04/11/10 12:32 PM
04/11/10 12:32 PM
Mopar_racer_99
Woodstock , Georgia
Yeah but I was not wanting to hear it, god I hate pulling heads. I believe the motor has Felpro 1039. Opinions stick with felpro or cometics, or? John
[Re: Al_Alguire]
#666854
04/11/10 02:24 PM
04/11/10 02:24 PM
Posts: 2,119 sc
tjmarcus1
sc
rings and guides won't have anything to do with that " fizzle and pressure" in the cooling sys.
[Re: tjmarcus1]
#666855
04/11/10 06:29 PM
04/11/10 06:29 PM
Mopar_racer_99
Woodstock , Georgia
Well we found the problem, the piston domes had been hitting the chambers and leaving peen marks in chambers. ???? How could the motor run so good like this? The gasket just finally had enough and gave up. John
#666856
04/11/10 06:41 PM
04/11/10 06:41 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Glad you found it! As to why it ran so good it depends on where the domes were hitting. As long as the contact wasnt cutting off any flame front it shouldnt of hurt any power. In fact if the contact helped with any extra chamber turbulence then it would of only helped, Well untill it lifted the head off the gasket enough times to lose the seal. By the way, did you know that today is the 40th anniversery of Apollo 13 when they made the statement "Houston we have a problem" Was your thread tital intensional or coinceidental. mike
#666859
04/11/10 08:05 PM
04/11/10 08:05 PM
Mopar_racer_99
Woodstock , Georgia
Now how do I fix the problem polish the chamber and dome and go .010 thicker on the gasket? John
#666861
04/11/10 09:09 PM
04/11/10 09:09 PM
Challenger 1
Cincinnati, Ohio
Just clearance the spot on the piston, don't run a thicker head gasket, that'll give up too much compression.
[Re: rowin4]
#666863
04/11/10 09:48 PM
04/11/10 09:48 PM
#666864
04/12/10 03:59 AM
04/12/10 03:59 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
1105's Fel Pro..
Chris..
#666865
04/12/10 09:49 AM
04/12/10 09:49 AM
Posts: 8,165 Left Coast
BobR
Left Coast
once I had a detonation problem and it sounds like the way mine looked. when re checked they were not hitting
I'd look into this. Why would a slight piston to head contact ruin the head gasket?
#666867
04/12/10 10:30 AM
04/12/10 10:30 AM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
The engine could have loosened up enough for the pistons to start hitting the heads. (rod , main bearing clearance, piston pin holes, rod bushings, piston skirts wearing letting piston "rock" in the bore), retorqueing head gasket, and also the piston expanding with heat. My new engine is tight, but the domes were lifting the head during mock up with no gasket. I had to clearance the cyl heads to fit with out lifting the head, then went with a .040" gasket. Brian
