3 bolt cam bolts how much torque? #666734
04/11/10 07:19 AM
04/11/10 07:19 AM
brisbane,australia
coletrickle Offline OP
brisbane,australia
Installing a new chain and gear set on a 440 with a 3 bolt cam.What is the torque value for the bolts?The book i have does not give any torque figures for the 3 bolts.Thanks guys.
Re: 3 bolt cam bolts how much torque? [Re: coletrickle] #666735
04/11/10 07:31 AM
04/11/10 07:31 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
35 ft lbs.
Re: 3 bolt cam bolts how much torque? [Re: coletrickle] #666736
04/11/10 07:33 AM
04/11/10 07:33 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
35-40lb.ft.
Re: 3 bolt cam bolts how much torque? [Re: coletrickle] #666737
04/11/10 11:32 AM
04/11/10 11:32 AM
NC
440Jim Offline
440Jim  Offline
NC
I use 35 ft-lb and Locktite.
Re: 3 bolt cam bolts how much torque? [Re: 440Jim] #666738
04/12/10 08:15 AM
04/12/10 08:15 AM
brisbane,australia
brisbane,australia
thanks for the help guys,much appreciated.
Re: 3 bolt cam bolts how much torque? [Re: coletrickle] #666739
04/12/10 08:31 PM
04/12/10 08:31 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Thanks for asking that ?, as I am bout to install a 3 bolt cam as well. May I ask what type of bolts you used, I will need to pick some up.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 3 bolt cam bolts how much torque? [Re: BloFish] #666740
04/13/10 07:44 AM
04/13/10 07:44 AM
brisbane,australia
brisbane,australia
BLOFISH I'm unsure of the bolts origin but i'm assuming they are the factory ones?The 440 is a complete mystery other than steel crank roller cam and very lumpy top pistons?Mopar sunday is comming up soon and we are pulling the 20yr old 440 out of my brothers 73 dart putting this 1 in and see how we go.The motor sounds super tough compared to his current low 11 sec engine would love to see it run a 10 fingers crossed.
Re: 3 bolt cam bolts how much torque? [Re: BloFish] #666741
04/13/10 07:50 AM
04/13/10 07:50 AM
ELYRIA,OH
ELYRIA,OH
a grade 8 would be best.i put an button head alan bolt in mine.it was easiest to modify for the cam button.[aluminum solid from comp cams]
