Piston pin issue? #666616
04/11/10 12:39 AM
04/11/10 12:39 AM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
I have KB pistons with full floating pins and Eagle H beam bushed rods. I was trying to get rods, pistons and pins together but they seem to be very "sensitive". I can put the pins in the rods with no issues, I can put the pins in the pistons with no issues. I just can't seem to the complete combo together. Almost like the top of rods are hitting the bottom of the pistons and not allowing me to slide them together straight.
Anyone experienced this? Is this just such a critical measurement that that I am just not getting everything straight enough?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Piston pin issue? [Re: jrlegacy23] #666617
04/11/10 12:50 AM
04/11/10 12:50 AM
Boise
Moparteacher Offline
Boise
I had a set of kb 162 pistons for a 383 and a set of Eagle rods. The small end of the rods were too wide and wouldn't fit into the piston without narrowing.
Re: Piston pin issue? [Re: Moparteacher] #666618
04/11/10 01:17 AM
04/11/10 01:17 AM
Cooperstown, NY
Cooperstown, NY
I have the KB841 (I think off the top of my head). The rods fit between the piston skirts fine. It just seems like they are not lining up with the rod end
Re: Piston pin issue? [Re: jrlegacy23] #666619
04/11/10 01:44 AM
04/11/10 01:44 AM
Put some grease on the top of the rod and try that, if the grease transfers to the piston its time to take action
Re: Piston pin issue? [Re: Cab_Burge] #666620
04/11/10 08:25 PM
04/11/10 08:25 PM
Cooperstown, NY
Cooperstown, NY
Everyone else's went together with ease?
