2.2L Radiator question #666592
04/10/10 10:35 PM
04/10/10 10:35 PM
Waterbury, CT
RamMan89 Offline OP
RamMan89  Offline OP
Waterbury, CT
My dad's 87 2.2L turbo non intercooled blew the radiator the other day after the cap went bad. I can take a radiator out of an 89 2.5L nonturbo car that I know is good and put it in there so he can get his car back on the road again. Question is are the two radiators the same? Napa's website lists the same radiator for both however we all know how that can go. Thanks for the help I need to get the car back on the road ASAP.
2004 Dodge Ram 3500 Cummins Diesel
1989 Dodge Power Ram W-150
Re: 2.2L Radiator question [Re: RamMan89] #666593
04/10/10 10:39 PM
04/10/10 10:39 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
I don't see why you can't.The intercooler is seperate.The only snag will be auto vs manual.Just plug the auto cooler lines if it's going to a manual.If the dimensions are the same,go for it.
Re: 2.2L Radiator question [Re: moretoys] #666594
04/10/10 10:55 PM
04/10/10 10:55 PM
Yes they are all the same if you dont need the cooler lines just plug them.they fit weather its a daytona k car whatever they will all fit.
Re: 2.2L Radiator question #666595
04/10/10 11:19 PM
04/10/10 11:19 PM
Waterbury, CT
RamMan89 Offline OP
RamMan89  Offline OP
Waterbury, CT
Awesome thanks guys, both cars are automatics so the cooler fittings won't be a problem.
Re: 2.2L Radiator question [Re: RamMan89] #666596
04/10/10 11:37 PM
04/10/10 11:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes the T1 rad is the same as a non-turbo rad. The intercooled cars ran a noticeably narrower rad, because the intercooler sat beside the rad. The T2 cars didn't get a bigger rad opening, so they narrowed the rad to squeeze them both in.
