Cooked Pushrod
#666349
04/10/10 08:11 PM
04/10/10 08:11 PM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
Was running the valves and found #3 intake pushrod was quite burnt from the cup to about 3/4 of an inch down. Lash was right where it was supposed to be. Pulled the rack out and discovered that maybe my clearancing between the rocker and the pedestal was too tight. Maybe the heat transfer could have done this? The pushrod does not show any signs of rubbing the head, the rocker did not show any signs of a plugged oil hole, shafts were installed correctly and i have about 95 passes on the motor. Any thoughts, or suggestions on what to inspect are welcome. 493, indy ez cnc'd heads, indy rocker set up, comp solid roller lifters, smith brothers pushrods. Steve
Re: Cooked Pushrod
[Re: biff426]
#666351
04/10/10 11:05 PM
04/10/10 11:05 PM
Plumcrazyracing
Central Coast
How many threads are showing under the rocker arm on the adjusting screw? pushrod could be too short
Funny you should ask that! I figure I might be about .060 too short. I have about 1.5 threads if not two below the rocker on the adjuster. Sounds good but Indy recomends that the threads not show. So I might have measured wrong. But would this really cause a heat issue in the pushrod like that?
Re: Cooked Pushrod
[Re: rowin4]
#666356
04/11/10 01:49 AM
04/11/10 01:49 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
I have cooked some pushrod cups do to the pushrods not being able to seperate from the adjusters balls long enough to allow oil to get in there The pushrod and rocker arm adjusters needs to be free enough for the two to have clearances from each other when the valve is closed If the other fithteen are doing okay I would look closely at the hurt one
Re: Cooked Pushrod
[Re: Cab_Burge]
#666357
04/11/10 08:39 AM
04/11/10 08:39 AM
Posts: 1,200 UK
602heavy
UK
I'm glad this came up , was checking lash & found 5 pusrods burn't , i have pr oiling along with spray bars , plenty oil up to the cup as i checked again yesterday , all these burnt pushrods are exhuast , these are brand new from Smith Bros , one thing i did'nt do was to lube the cups before fire up , did'nt think this necesary due to oiling direct to cup , funny the ex have taken the hit , all adjusters are within spec of Jessel (adjuster nut flush with top of adjuster) , i just don't know why this happened? , had four spare to which i lubed before intall , will pull the covers & check again after a good run.
Re: Cooked Pushrod
[Re: rowin4]
#666358
04/11/10 09:12 AM
04/11/10 09:12 AM
Posts: 415 Peru
cbarracuda
Peru
I guess I don't understand what the push rod length would have to do with the burning of the cup. If the adjuster is to short it will hit the rocker [ not good ] or if the adjuster is to far out it will possibly break the adjuster ball off. But at 1 1/2 threads out , that's within normal adjustment. I'd look for lack of oil as you said the adjustment was correct.
lengh affects the geometry
Re: Cooked Pushrod
[Re: Plumcrazyracing]
#666360
04/11/10 01:05 PM
04/11/10 01:05 PM
Cab_Burge
Do the hurt pushrods slide up and down easily or is the rocker tightness help bind them up a littel? As far as rocker side clearances my opinion is like every other part in a race motor "looser is better than a tiny bit to tight"
Re: Cooked Pushrod
[Re: Cab_Burge]
#666362
04/11/10 01:19 PM
04/11/10 01:19 PM
Plumcrazyracing
Central Coast
Don't quite understand what you mean by slide up and down. As i adjusted/checked lash the pushrods were not jammed or obstructed. The pushrod clearance through the heads was normal with no signs of interference. On the other hand, some select rockers were not quite that 'free'. Looking at it that way, i guess the rocker may have bound a little and caused more of an impact on the pushrod.
Re: Cooked Pushrod
[Re: cbarracuda]
#666363
04/11/10 01:22 PM
04/11/10 01:22 PM
Plumcrazyracing
Central Coast
.060 too short is ok in a low tension spring,spring load play a part.Also aluminum roller rokers like no thread showing below the rocker arm
240 on the seat and 495 open. 1.86'sh installed height. I need to check my build notes on the exact installed height.
Re: Cooked Pushrod
#666364
04/11/10 01:27 PM
04/11/10 01:27 PM
Posts: 415 Peru
cbarracuda
Peru
That's a High tension spring for a roller cam. I'm sure a longer push rod will fix your problem.
Re: Cooked Pushrod
#666365
04/29/10 07:02 PM
04/29/10 07:02 PM
Posts: 191 WI
mopar873
WI
I'm feelin' your pain. I installed a new set of Indy rockers on my Iron block with 440-1s. I had two intake pushrods that not only cooked, but also had their cups deform outward. These are the same pushrods used on the last set of 1.5 rockers. I took the shafts off and saw the witness marks on the rocker from compressing the pushrod cup. Curiously enough this only happened on two cylinders. After having checked everything, and "clearancing" the rocker arms a bit, I tried original length again. Another burned/deformed pushrod. Then I went to two pushrods that were about .040 shorter. Now they are getting warm the first inch down from the cup and it appears they don't get as much oil as the others. I can't understand why on only two cylinders, but if this thing keeps pi$$ing me off, I am going to thru-pushrod oiling and the proper roller lifters. What I don't know is how tolerant these pushrods are to heat. I dont want to have a cup pop off and play tag with my rotating assembly!! BTW, the adjusters showing are consistent with all the other rockers. any comments would be great
Re: Cooked Pushrod
[Re: mopar873]
#666366
04/29/10 07:29 PM
04/29/10 07:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
There are a couple different styles of rocker arms, one will have a squirter hole that squirts oil towards the cup.... if the push rod length is wrong the oil doesnt squirt INTO the cup(may miss the whole area and if thats the case all its doing is spraying oil on to the head... check what style you have... the other style has the oil come across the arm(internally in the arm) and comes out right at the cup area also some of the cheaper arms I've seen the squirter hole was aimed wrong and missed
Re: Cooked Pushrod
#666368
04/29/10 09:58 PM
04/29/10 09:58 PM
Cab_Burge
I have seen (on a 426 Hemi motor) exhaust pushrods rubbing on the head cause those ones to burn the pushrod ends(rocker arm end tips) up What I'm trying to say is if the pushrod is rubbing on the heads and the rocker arm adjusters are prying on the tips of the pushrods not allowing them to have enough free play to allow the pushrod to drop down away from the adjusters no oil will get in there so they burn up from a lack of oil IHTMS
