Why would exhaust system be grounded? #666340
04/10/10 08:05 PM
04/10/10 08:05 PM
Kirkland, Washington
Pacnorthcuda Offline OP
93 Dodge Stealth, the mid pipe has a small ground strap. Why? The front pipe has the O2 sensor.
Just wondering.
Re: Why would exhaust system be grounded? [Re: Pacnorthcuda] #666341
04/11/10 09:08 AM
04/11/10 09:08 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Somene in Japan probably knows.
Re: Why would exhaust system be grounded? [Re: Magnum] #666342
04/11/10 09:43 AM
04/11/10 09:43 AM
BDW Online content
BDW  Online Content
I'd guess because of the O2 sensor. How far away is the strap? If the ground is not close to the circuit it can create inaccurate voltages/readings.
Re: Why would exhaust system be grounded? [Re: BDW] #666343
04/11/10 10:15 AM
04/11/10 10:15 AM
The strap is about two feet away from the O2 and on a different pipe. I googled grounded exhaust and came across some claims that static electricity build up in the exhaust stream can actually hinder flow but I never heard of that one before! I don't buy it.
Re: Why would exhaust system be grounded? [Re: Pacnorthcuda] #666344
04/11/10 10:32 AM
04/11/10 10:32 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Possible answer: The O2 sensor
WAG answer: exhaust flow inside the pipe causing a static electricity charge that could zap the O2
Silly answer: the OE wanted to add a little more time to round up to the nearest tenth for labor, have another excuse for denial of warranty if the strap was off, and make the car more complex....
Re: Why would exhaust system be grounded? [Re: Pacnorthcuda] #666345
04/11/10 10:42 AM
04/11/10 10:42 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
OK, then how about to prevent any possible arcing that could cause unburned gasses to explode?
Re: Why would exhaust system be grounded? [Re: stubbs300 ] #666346
04/11/10 11:31 AM
04/11/10 11:31 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
It,s for the muffler bearing overide control solenoid actuator module.
Re: Why would exhaust system be grounded? [Re: ChinooK440] #666347
04/11/10 12:20 PM
04/11/10 12:20 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Why would exhaust system be grounded? [Re: ChinooK440] #666348
04/11/10 12:26 PM
04/11/10 12:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
2 reasons,
1st for a solid ground path for the 02 sensors(primarily for the earlier single wire sensors)
2nd prevent static electricity.
As cars get more complex, poor grounds have become the predominant issue causing complaints. Which is why you'll find automobiles have for the most switched from B+ control( pre-war technology ) to ground control in the past 10 -15 years thru today
Also the imports have always relied heavily on grounds to control operating systems so you'll find them much more prevelant on the import cars
