Leak in water jacket #666212
04/10/10 05:23 PM
04/10/10 05:23 PM
Hannibal Missouri
71dart Offline OP
3 yrs. for 500 posts
71dart  Offline OP
Hannibal Missouri
I just put a set of new aluminum mopar performance heads on my 360, now the last bolt on the intake on the passenger side leaks water, any ideas on how to get this to stop leaking? Please advise.
Mike
Re: Leak in water jacket [Re: 71dart] #666213
04/10/10 05:32 PM
04/10/10 05:32 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
None of the intake bolts should go into water unless the alum heads are different.
are you sure that the gasket is in place.
Re: Leak in water jacket [Re: 71dart] #666214
04/10/10 11:30 PM
04/10/10 11:30 PM
Pull the intake and see where specifically the water is coming from and when going back together I'd toss the front/rear gaskets and use a wide carefully placed swath of clear silicone on cleaned surfaces as alot of the supplied gaskets are slightly too thick and can hold the intake up just enough for the front water port(s) to leak but this is different & must be checked out.
