diaper carnage! #666096
04/10/10 02:35 PM
04/10/10 02:35 PM
Diego-Town, CA
Diego_Ted Offline OP
Diego-Town, CA
This is the result of half a dozen runs! The diaper was not lying of the headers but was very close. The headers were wrapped with asbestos header heat tape.
I am weary of buying an expensive diaper if the same thing is going to happen? I like the idea of a diaper but if this is going to be the result what's the point.
Are other SB guys with a stock K member having the same problem?
Diego
Re: diaper carnage! [Re: Diego_Ted] #666097
04/10/10 02:39 PM
04/10/10 02:39 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Was that an off the self diaper or one custom made for a small block in a stock K frmae?
Re: diaper carnage! [Re: WILD BILL] #666098
04/10/10 02:49 PM
04/10/10 02:49 PM
Diego-Town, CA
Diego-Town, CA
It was from JJ performance, he said he had uses them in A bodys all the time? Yea you can get them in but there is very little wiggle room. HOLLYWOOD fought to get this one in place. I mean it goes in and from the top it will make tech happpy?
Diego
Re: diaper carnage! [Re: Diego_Ted] #666099
04/10/10 03:21 PM
04/10/10 03:21 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Dragnduster had a nice one made for his car.
Pics in THIS POST
When I get the funds that will be what I get.
Re: diaper carnage! [Re: Diego_Ted] #666100
04/10/10 03:27 PM
04/10/10 03:27 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Ted;
I bought a custom fitted unit from Taylor that is fully 7.2 cert with anti burn material on the outside and on my big block the diaper actually touches the headers in a couple of spots.Other than a noticeable brown spot, diaper is in it's second season and going strong. A little pricey but cheaper than replacing a standard diaper every few runs.
Tom
Re: diaper carnage! [Re: Dart Racer] #666101
04/10/10 05:01 PM
04/10/10 05:01 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
They will custom make you one
http://www.stroudsafety.com/
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: diaper carnage! [Re: bigdad] #666102
04/10/10 07:17 PM
04/10/10 07:17 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Russ is local to me and has made quite a few blankets for PSCA cars as well as Glen Willets (member Wyoming) car and a couple of his friends.
http://russlerii.com/
Re: diaper carnage! [Re: Diego_Ted] #666103
04/10/10 08:27 PM
04/10/10 08:27 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Have to agree with ya.
put a diaper on that fit ok, stupid me figured they wouldnt sell something that melts.
Moronic sfi should mandate wire attaching straps rather than nylon or other heat decomposing material.
Or somebody offer something like it.
Why is it when you want something you have to make it yourself.
Wanted grommets, tooling and spool of small wire rope.
Anybody have ideas?
Sorry for rant but feelin' your pain also.
Re: diaper carnage! [Re: theclutcher] #666104
04/11/10 11:05 AM
04/11/10 11:05 AM
Diego-Town, CA
Diego-Town, CA
I will have to look at a custom one once HOLLYWOOD tells me which pan we are going to use? HOLLYWOOOOOOOOD. Hollywood has been fighting a nasty bug since before MATS and is under the weather, we will get it sorted out soon!!
TAKE CARE OF THAT BUG AND GET BETTER MY FRIEND!!
dIEGO
Re: diaper carnage! [Re: Diego_Ted] #666105
04/11/10 01:00 PM
04/11/10 01:00 PM
Lehigh Acres, Florida
rickstershemi Offline
Ted, I would contact Dennis @ DRE, he will fix you up with what you need and is reasonably priced
Rickster
Re: diaper carnage! [Re: Diego_Ted] #666106
04/11/10 02:02 PM
04/11/10 02:02 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ted we had to actually have the heat shielding material sewn onto the diaper when I ran the Hemi. Worked well it is stil on the car now withthe B1 but does not get near anything. I thought you were posting the damge from the wheelstand. When I did it I tore mine up too.
