Wax and grease remover on vinyl top ???? #666019
04/10/10 12:28 PM
04/10/10 12:28 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
The guy that did the detail work on my 72 Challenger got some wax on my aftermarket vinyl. Can I use wax and grease remover to remove it? what is the best/safest thing to use?
Re: Wax and grease remover on vinyl top ???? [Re: Boise Chall] #666020
04/10/10 01:03 PM
04/10/10 01:03 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
I use a product called spray 9 and my white top is still mint after 3-4 yrs. It seems to do a great job of cleaning.
Re: Wax and grease remover on vinyl top ???? [Re: dd340] #666021
04/10/10 01:18 PM
04/10/10 01:18 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
What exactly does that do,just clean??What do you put on it after that,if anything.Someone said on here that 101 or 303 what ever it is,doesnt have silicone in it.I ruined a white top with armor-al,so dont put that on a white top.You can get away with it on black.Thanks
Re: Wax and grease remover on vinyl top ???? [Re: 70RR383] #666022
04/10/10 01:53 PM
04/10/10 01:53 PM
Columbus Ga
reflections7 Offline
Columbus Ga
Formula 303. they sell it at most boat stores for boat interiors also year one sells it in the back of there mags
Re: Wax and grease remover on vinyl top ???? [Re: reflections7] #666023
04/10/10 02:04 PM
04/10/10 02:04 PM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Sold almost everywhere.
http://www.303products.com/
My
Own
Personal
Adrenaline
Rush
Re: Wax and grease remover on vinyl top ???? [Re: Boise Chall] #666024
04/10/10 11:35 PM
04/10/10 11:35 PM
Iowa
dsp Offline
dsp  Offline
Iowa
Goop hand cleaner works excellent to clean vinyl tops. Use the original formula Goop, not the pumice or orange stuff. Since Goop is very effective at cutting wax, don't let it drip down across the paint unless you are planning on rewaxing it.
Re: Wax and grease remover on vinyl top ???? [Re: dsp] #666025
04/11/10 12:40 AM
04/11/10 12:40 AM
Boise Idaho
Boise Idaho
I was able to find the 303 cleaner and the 303 aerospace protector used it and it worked great thanks
