Page 3 of 15 1 2 3 4 5 14 15
Re: "Don't ask me how I know..." [Re: MTTwister] #653
07/11/03 06:34 PM
07/11/03 06:34 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Hydraulic lock due to about one quart of fuel in each cylinder is not only a reality, but a definite possibility with any carb design regardless of brand. The trick is to have at least a 100gph electric pump, and make sure the float sticks. Voila.
There must be coolant in the system before the gauge will read anything but dead cold. The car appears to never warm up. It must need a thermostat, eh? Uh, nooo...
904 converter snouts rotinely just shear right off with no warning 50 miles from home, yet at the same time they are the greatest transmission in the world and everybody should have one.
3 grenaded 904 transmissions over 5 years in the same car does a great job of rustproofing the trans tunnel, but doesn't stop the frame from rusting out and breaking.
Rich H.
Esse Quam Videri
Re: "Don't ask me how I know..." [Re: motorheadjohn] #654
07/11/03 06:43 PM
07/11/03 06:43 PM
Fischer, TX
dodgepu360 Offline
dodgepu360  Offline
Fischer, TX
if you forget to hook up the field wires on the alternator it won't charge
a 4x4 truck can be driven for weeks without the rear drive shaft
the same truck can also be driven without the power steering hoses and clutch linkage
it is NOT a good idea to pour gas down the carb to keep an engine running
you cant drive a car vary far before it starts going in a circle if it is missing the steering box
locking hub off of a dana44 will fit on a chevy 10bolt front end but they won't lock
bungy cords do not make good battery hold downs, but ratchet straps do
Re: "Don't ask me how I know..." [Re: dodgepu360] #655
07/11/03 07:03 PM
07/11/03 07:03 PM
Portland Oregon
69Dartman Offline
69Dartman  Offline
Portland Oregon
A sure grip, a V8, rain, and a A body will tend to do a abrupt u turn with very little warning.......
Knocking off the extra blade of the fan on your Jeep after it loses one to rebalance it is a bad idea.....
If the tree your trying to winch yourself out with is small
It will move before your Power Wagon will with interesting results.....
Losing the carb return spring at an intesection can really do a good job of killing mosquitoes and tends to attract any nearby sherrifs......
Trying to reinstall your wiper arm with a hammer is a really bad idea.....
Life's a little bit better when you hit a Camaro.
Re: "Don't ask me how I know..." [Re: 69Dartman] #656
07/11/03 07:21 PM
07/11/03 07:21 PM
Santa Rosa, NOR*CAL.
Just Cameron Offline
Wipers can be operated manually (Like windows) IF you have a big enough hole where your radio and ashtray used to be.
Re: "Don't ask me how I know..." [Re: Just Cameron] #657
07/11/03 07:29 PM
07/11/03 07:29 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
If you leave the hood pins out after going through tech, don't worry the hood will stay there. Don't ask me how I know.
69 GTX 68 Road Runner
Re: "Don't ask me how I know..." [Re: BSharp] #658
07/11/03 07:46 PM
07/11/03 07:46 PM
Sacramento, CA
jahsh Offline
super gas
jahsh  Offline
super gas
Sacramento, CA
When you think you have a bad rear main seal and drop the oil pan and replace the seal.. twice, it could still be an easy of a fix as a bad 90% oil adapter seal;)
Re: "Don't ask me how I know..." [Re: last426] #659
07/11/03 07:47 PM
07/11/03 07:47 PM
If you don't put a bowling ball into a bowling ball bag before you put it in the trunk it will roll from side to side with every turn and dent you trunk from the inside out (at least that's what I heard).
buying a set of 3.91s and driving home with them in the trunk can result in dented quarter panel.
pulling the fuel sender out of a 57 ford pick up then using a match for a light to see if you have enough gas to go cruising will result in a blow torch effect inside the cab!
getting a closer look at the green stain on one of the ribs of a "fit all" radiator hose isnt a very good idea, especially if the car is at 210 degrees, your not wearing safty glasses and you have your face 6 inches away from green stain. and never never trist the hose to see if its acually a coolant leak! . that might hurt very badly for several days!
never "feel" your brake rotor for scratches through the holes in your wheel with your finger right after going down a steep hill in stop and go traffic.
Re: "Don't ask me how I know..." #660
07/11/03 08:15 PM
07/11/03 08:15 PM
Red Deer, Alberta
bill_greenwood Offline
Red Deer, Alberta
If you "buzz it and dump the clutch" in reverse, the least bad thing that will happen is that your driveshaft will exit the car. Don't ask...
Re: "Don't ask me how I know..." #661
07/11/03 08:19 PM
07/11/03 08:19 PM
a 5HP go-cart wont turn 90 degrees at full throttle.....
Re: "Don't ask me how I know..." [Re: bill_greenwood] #662
07/11/03 08:25 PM
07/11/03 08:25 PM
In the process of installing headers & giving up for the night,make sure engine has dropped all the way into k-frame before closing hood...
Re: "Don't ask me how I know..." [Re: bill_greenwood] #663
07/11/03 08:31 PM
07/11/03 08:31 PM
Red Deer, Alberta
Red Deer, Alberta
Or; If you are getting your chainless bicycle towed down a sloping street by another bike, when you start to overtake your towbike, do not tell him "whoa!"...
Re: "Don't ask me how I know..." [Re: bill_greenwood] #664
07/11/03 08:37 PM
07/11/03 08:37 PM
Red Deer, Alberta
Red Deer, Alberta
If you have small feet, jumping on the spokes of your big brother's bike just to make him mad might not be a good idea...
Re: "Don't ask me how I know..." [Re: bill_greenwood] #665
07/11/03 08:44 PM
07/11/03 08:44 PM
You just finished changing out the center carb on your 6pk 4spd car and want to check for fuel leaks with no one to help you, soooo... you hook up your ignition bye pass switch, while standing an leaning over the rad, you try and start the car to check for leaks, and its in gear.......... ice works good on knees for 3 days......Don't ask me how I know
Re: "Don't ask me how I know..." #666
07/11/03 09:20 PM
07/11/03 09:20 PM
Midwest
Chargerfan Offline
Chargerfan  Offline
Midwest
NEVER start a motor up without the oil sending unit in place. Don't ask me how I know!!!!!!
2011 Challenger R/T
2017 Ram 1500 BIG HORN Edition
Re: "Don't ask me how I know..." [Re: Chargerfan] #667
07/11/03 09:35 PM
07/11/03 09:35 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
22 year old heater hoses disentigrate from the inside out, thereby breaking open at the outlet on the engine, at the time where you dont have water. Said hoses will also clog up your outlets bigtime.
If you have any loose skin from bending your hand, keep it away from the release handle on your vice-grips. Hurts like H*ll when it gets pinched!
Dont sit on a fender and proceed to take your head out from under the hood unless you're hanging onto the lip of the hood.
When the eye of your Neg Battery cable burns out and fails, its gonna do it at the least conveniant time (liek when you have Ice-cream)
Manual transmissions and hills are good things, especially if your starter or said negative battery cable eye burns out.
Ok, thats just a few!
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: "Don't ask me how I know..." [Re: MoPar Jamie] #668
07/11/03 09:48 PM
07/11/03 09:48 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
Watching a Chevy guy look under the hood of your Charger is worth all of the stupid comments when he hits the back of his head on the secondary latch mechanism.
Old rubber spark plug wires will burn to a crisp on your first truck if you have a fuel leak and a spark.
If you do not have a spare tire you will have a flat no matter how good and new the tires are on your vehicle.
Re: "Don't ask me how I know..." [Re: TheBlueBeast] #669
07/11/03 09:59 PM
07/11/03 09:59 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
It is possible but VERY painful to power shift a 4-spd at the strip after having kicked the front rim as hard as you can and breaking your big toe on your left foot.
Re: "Don't ask me how I know..." [Re: TheBlueBeast] #670
07/11/03 09:59 PM
07/11/03 09:59 PM
An injector assembly machine, will finish a cycle, No matter if it errors out and an engineer tells you it will not run again, until you hit the start button
Monday nite, 4 hours in the hospital.
Re: "Don't ask me how I know..." #671
07/11/03 10:11 PM
07/11/03 10:11 PM
OH and Bud light helps too.....
Re: "Don't ask me how I know..." #672
07/11/03 10:13 PM
07/11/03 10:13 PM
On The Boat, On The Lake, Wa. ...
amxautox Online content
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Online Content
The horozonal boring machine will NOT stop by wraping your body around the spindle! No not me. A guy at work a few years ago.
You can not stop a drill press spindle by grabbing the big DRILL in the chuck. Another guy at work about the same time.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
