440 Head Gaskets water passages don't match. Help!!!! #665826
04/10/10 01:13 AM
04/10/10 01:13 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
Ok, I've been battling this overheating problem forever, and it has to be internal, because I've tried EVERYTHING else (please don't ask me if I have a fan shroud)!!!
Now, I'm tearing down the motor and I bought some new head gaskets and I noticed something interesting. The water ports above/between the cylinders don't match up. The Felpro 8519PT-1 only has a "slit" in it, but there is a nice sized hole in the head and block obviously restricting the water flow. See pics.
Do I have the wrong gasket?
What do you recommend?
Desperate and I want to get this done this weekend. NO theories, just answers please!!!
Thanks in advance!
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: Cudalord] #665827
04/10/10 01:17 AM
04/10/10 01:17 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
The Gasket...
Re: 440 Head Gaskets water passages don't match. Help!! [Re: Cudalord] #665828
04/10/10 01:52 AM
04/10/10 01:52 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
that's what the gaskets are supposed to look like, those are sometimes referred to as "steam holes" and most of the water flow happens in the two big passages at the front and rear of the head. i don't know why they are like that but i've never seen a big block any different than that. in that first pic it sure looks like the water passage in the block is full of crud, which would surely cause heat issues.
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: Cudalord] #665829
04/10/10 01:56 AM
04/10/10 01:56 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
and I noticed the passages below are blocked as well... I can't be the first one to come across this...
Re: 440 Head Gaskets water passages don't match. Help!! [Re: dirtybee] #665830
04/10/10 02:00 AM
04/10/10 02:00 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
If it's just a "steam hole", then why would it matter if it was a bit crusted or not? I thought it was full of crud because the gasket I took off was identical to the one that I'm putting on. Sorry, should have mentioned that...
Re: 440 Head Gaskets water passages don't match. Help!! [Re: Cudalord] #665831
04/10/10 08:19 AM
04/10/10 08:19 AM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
it looks to me like your coolant passages in the block may have a lot of build up of deposits. this will not only restrict coolant from flowing properly but also limit the transfer of heat from block to coolant. if your block looks like that, the heads and rest of the system are likely similar, i would get a screwdriver and poke through the crud and try to clean out the block. and heads too. this is way easier to do with the block out of the car so you can remove freeze plugs and really blow everything out of there with a pressure washer and whatever you can get in there also, do you run a fan shroud? just kidding.
Re: 440 Head Gaskets water passages don't match. Help!! [Re: dirtybee] #665832
04/10/10 09:14 AM
04/10/10 09:14 AM
At 1st I thought that was just a block pic for reference but if that is the "one" it (the block) for sure needs to be baked clean. W that amt of crud it will unfortunately never be right. I'd also (w a freeze plug/jb weld) plug the large irrregularly shaped large block water passage in the rear of each deck, as said punch out the slits to match the figure eight top passages AND drill an 1/2" (at least) hole in the block/deck/gasket between #3 and #5, and #4 and #6 cyls in the outer edge of the deck adding a completely new water passage. The proper place on this edge there's 2 outer head bolt holes and you want to drill the 1/2" passage "in/up" so that it makes a triangle w the 2 head bolt holes. 2 ex valves are paired at that point and that alot of blocks have NO passage there and it is exactly the spot that needs a passage and a large one at that. And an anti cavitation plate welded on the pump vanes and at least a 1-1 crank/wp pulley ratio. Good luck to you on this dilemma and holler on what you think & how it turns out
Re: 440 Head Gaskets water passages don't match. Help!! [Re: RapidRobert] #665833
04/10/10 10:32 AM
04/10/10 10:32 AM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
? Wouldn't blocking the rear water passages keep coolant making it to the rear of the head/deck? Can anyone confirm this? All searches state that the passages are blocked to restrict coolant flow and it's not necessary to modify the gasket.
Thanks again.
Re: 440 Head Gaskets water passages don't match. Help!! [Re: RapidRobert] #665834
04/10/10 01:33 PM
04/10/10 01:33 PM
Scottsdale, AZ
Cudalord Offline OP
Cudalord  Offline OP
Scottsdale, AZ
There really isn't that much crud on it, most of it is just scaling and it brushed right off.
After doing more research on this, I've seen a lot of guys recommend drilling 3/8" holes through the head gasket to allow water through the two lower passages, and that's it.
Re: 440 Head Gaskets water passages don't match. Help!! [Re: Cudalord] #665835
04/10/10 08:56 PM
04/10/10 08:56 PM
yes and that is what you want as stock the flow has a tendency to just rush to the rear past the inner (valley) sides of the cyls & some goes up in the head and some goes down around the cyls but not near enough goes down and around the cyls. This causes hot spots that induce pinging and force mixture compromises that hurt power. Plugging the rear large passage will force more coolant down around the cyls & toward the outside where it is the hottest/needed the most. If you choose to do this you would want to drill a 1/8" hole in the freeze plug so air pockets can escape. CRITICAL is the added hole between the aforementioned cyls and if you drill a 1/2" (or 3/8) you'll be able to look in there and see how close you are to the inside cyl walls. As long as you have plenty of head gasket space (surface) and are not drilling into something you shouldn't you are structurally sound
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: Cudalord] #665836
04/11/10 10:14 AM
04/11/10 10:14 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
This discussion came up months ago.. There was a change in head gaskets, maybe in the late 70s or so. The round holes were eliminated in favor of slots. I locate the exact place where the holes need to be and repunch the head gasket. I have a set of FelPros done that way on a max wedge and I can't even get it to heat up now. Maybe a little to much flow now??
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: 52savoy] #665837
03/17/12 10:41 PM
03/17/12 10:41 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
Hi, Has anybody had simliar problems with the felpro 1009 head gaskets?, I have an over heating issue and talked to Larry Shepard and he said he "punches" every set he uses. I had an engine shop rebuild my engine and I'm guessing they didn't know about this. any comments will be appreciated.
Semper Fi
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: GOLDMYN] #665838
03/18/12 01:06 AM
03/18/12 01:06 AM
Amherst,NY
challengermike Offline
Amherst,NY
i have used the Felpro 8519PT-1 gaskets on a bunch of engines and have not modified any thing and never had a cooling issue. My 499 ran 160 in 90 degree heat sitting in traffic with junkyard dual fan setup and a double pass rad.
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: Cudalord] #665839
03/18/12 02:35 AM
03/18/12 02:35 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Transfer slots are common discussion in Jensen Interceptor forums. Small engine compartments make cooling an issue....
I went to the Jensen Monday Club website, the tech section shows how to enlarge the transfer slots.
I roughly tripled the width of the transfer slots on my Jensen's Felpro gaskets.
CrAzYMoPaRGuY
Re: 440 Head Gaskets water passages don't match. Help!! [Re: RapidRobert] #665840
03/19/12 12:42 AM
03/19/12 12:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hundreds of thousands of big blocks have run that gasket as it comes out of the box and never had a problem.
The OP has an issue and doing what you suggest is a bandaid masking the problem.
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: 52savoy] #665841
03/19/12 12:45 AM
03/19/12 12:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There was NEVER a round hole , the original head gaskets from my 69 383 have a rectangular shaped hole instead of the slit, no other holes added . I can't see it making a huge difference .
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: Cudalord] #665842
03/19/12 01:11 AM
03/19/12 01:11 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
cylinder head gaskets are designed with certain size slots/holes for a reason. they are meant to properly distribute and control coolant flow, i seriously doubt the head gasket design is the cause of the problem.
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: JohnRR] #665843
03/19/12 09:35 AM
03/19/12 09:35 AM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
Huge difference ?, My car is a 1971 Charger R/T that has the stock 22" radiator, I've got a "Glen-Ray" radiator and my car runs at 190 cruising and creeps to 200 at stop signs, IYHO would the change in gasket ie (punching a bigger hole" bring it down 5-10 degrees?...thanks
Semper Fi
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: GOLDMYN] #665844
03/19/12 09:46 AM
03/19/12 09:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think so, the holes in the block and the head are not directly over each other so making the holes bigger is going not to change this or make the connection between them that much greater.
That said sometime after 71 or so the factory did change that hole in the block to a figure 8, but they didn't change the head gasket.
Some claim to have seen lower temps by adding the 2 holes in the gasket where those lower holes are covered by the gasket but if I remember right this was on extreme race builds ???
I'm guessing your build is more than the 22" rad , especially if you had it done as a 2 row , is capable of cooling , though I don't know what your cooling system consists of .... rows in your core , thermo temp , shroud , fan type ...
This is the original head gasket from my 69 383 , it has a 18xxxxx part number on it .
Re: 440 Head Gaskets water passages don't match. Help!!!! [Re: JohnRR] #665845
03/19/12 12:20 PM
03/19/12 12:20 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
Thanks for your response, the radiator is 3 row 22", 180 stat,8 blade water pump, direct drive w/factory fan,factory spacer, factory shroud. Whats your thoughts on crusing at 190?, The cars does run good and doesn't ping, or puke, autometer temp guage, Thanks again!
Semper Fi
