Bleeding manual brakes with prop valve #665783
04/09/10 11:15 PM
04/09/10 11:15 PM
PA
moparboy66 Offline OP
PA
I am bleeding the manual brakes (first time) on the '66 Coronet, rear drums and SSBC-kit manual discs front. All new M/C, lines and all hardware.
I bench bled the M/C- bubbles gone and fluid clear. I gravity bled the front brakes, bubbles gone, clear fluid now and closed the bleeders.
But I cant seem to get the rear brakes to start gravity bleeding. I have the SSBC supplied proportional valve (labeled "increase"/ "decrease") for the rear brakes mounted about a foot and a half or so from the M/C port.
I set the rear prop. valve to max "increase" setting. After two hours with both rear bleeders open, I still haven't seen the reservoir level drop at all.
Is there anything special I have to do to get the gravity bleed started because of that inline prop valve, and is the max increase setting correct?
Re: Bleeding manual brakes with prop valve [Re: moparboy66] #665784
04/10/10 12:04 AM
04/10/10 12:04 AM
Any possibility that the valve is in there backwards and the proportioning is shut down completely? If not crack the line into it & see if it has flow when someone presses the pedal
Re: Bleeding manual brakes with prop valve [Re: RapidRobert] #665785
04/10/10 11:51 AM
04/10/10 11:51 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Pump the brake pedal until you get some fluid flowing.
Re: Bleeding manual brakes with prop valve [Re: moparboy66] #665786
04/10/10 09:36 PM
04/10/10 09:36 PM
PA
PA
Thanks guys!
I disconnected the OUT line at the prop valve, and no fluid.
I set the prop valve to about 50% of range, and a couple of pumps of the pedal later the problem was gone.
I just expected the line to start gravity bleed without pushing the fluid with the pedal. Thanks again.
