'70 Coronet disks on '69 Charger?
#665470
04/09/10 06:31 PM
04/09/10 06:31 PM
Posts: 738 OK
David_Trimble
OK
My '69 Charger once had front disks, but for some reason had been switched to drums many years ago. I know this because I had found (thru the help of Moparts.com) that my current master cylinder/power booster were meant for disks- plus I still have the factory proportioning valve that was only used in a disk setup.
I've been thinking of doing the disk conversion outlined here on the board but one of the members of the local Mopar club that I'm in had mentioned to me that he has a '70 Coronet parts car with factory disks. While it's missing the rotors and calipers, it does have the steering knuckles- and I found that I can get rebuilt calipers and disks at Autozone.
So my question - can a '69 Charger run front disks off a '70 Coronet?
Thanks! David
'69 Dodge Charger R/T
Re: '70 Coronet disks on '69 Charger?
[Re: David_Trimble]
#665471
04/09/10 07:06 PM
04/09/10 07:06 PM
Andrewh
[Re: Andrewh]
#665472
04/09/10 09:52 PM
04/09/10 09:52 PM
Posts: 738 OK
David_Trimble
OK
so it's a straight bolt in? From what I understand, the '69 B-bodies had the 4-piston calipers- from what I saw online for the '70 Coronet, it uses a 2-piston? I heard that there were problems with the 4-piston (possibly the reason why my Charger was converted to drum?), I take it Chrysler corrected that in 1970 with this version?
[Re: David_Trimble]
#665473
04/10/10 09:30 AM
04/10/10 09:30 AM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I think the big reason, besides scarcity of donor parts, for doing the A body spindle/single piston caliper swap is that the replacement rotors and calipers are very cheap.
Are you sure this coronet donor has multiple piston calipers? I did the Mopar action disc brake swap on my charger many years ago and I remember going in telling them to give me calipers for a 70 charger. They were single piston, pin type calipers.
If you can, i'd stick with the single piston calipers unless your going aftermarket wilwood/pbr, etc... for a serious autox/racecar.
....which may be possible if the calipers for those coronet spindles are what I thought. If not, i'd be hunting for the A/F/J/M spindle & adapter combo.
[Re: David_Trimble]
#665475
04/10/10 10:49 AM
04/10/10 10:49 AM
Pool Fixer
Coram, NY
For '69s I understand that the 4-piston calipers were used. When I looked up rebuilt calipers for '70 Coronets I was shown 1-piston calipers (I think I posted '2-piston' previously, that's incorrect), so I assumed that there was a change in design that year. You can see the rebuilt calipers I was looking at Here But I'm going for a stock setup so the 1-piston variety would be fine with me. While of course it wouldn't be concours-correct, I would think a 70 B-body disk setup would be closer to a original '69 setup than the disk conversion setup (and certainly better than the 10" drums that I've got right now)....
gotcha...so my memory is better than I thought cause those calipers you pictured are the same as what I have. Going back yet again to what I remember from the mopar action article, I think that the problem you will have now is rotors. I seem to remember that late 60's and maybe 70 used a two piece rotor. probably expensive and said to warp easily. I used the one piece 11.75 rotors and the slightly bigger caliper brackets required to clear them. I think your issue will be that the later, cheaper, bigger, one piece rotors may not fit on those spindles. and then theres the caliper brackets.
After an accident last year, I needed a spindle. I had previousely put the A body spindles on my 68 charger. I was offered a set of 69 charger spindles for free but asked on moparts and was told they would not work with my rotors and/or caliper adapters.
IMHO, i'd rather buck up now a little more for the more common A/f/j/m spindles & rotor & adapter combo now and know i'd save money and hassles with replacement parts later
then there's the cost factor of the parts you were offered already. that plays into it too.
[Re: Pool Fixer]
#665479
04/10/10 09:06 PM
04/10/10 09:06 PM
Posts: 738 OK
David_Trimble
OK
Well, I was over at the guy's house just now looking at the Coronet and it turns out that the rotors are still on it, but the calipers are definately missing (including the mtg hardware- that might be a problem to find ) The rotor looks pretty rusty so I doubt it'll be usable, but I at least have the rotors and bearings to use for comparison for replacements. I'll check with Autozone and NAPA to see if they can't get information as to what kind/size of bearings are required for their rotors.
[Re: David_Trimble]
#665480
04/10/10 10:29 PM
04/10/10 10:29 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
If the Charger doesn't have a sway bar it will work.However if it does have a sway bar the calipers will hit the tabs on the lower control arms.If you want the sway bar you would need to swap the lower control arms sway bar and k frame from the 70.All these parts are a direct bolt in.
NS1AAR
[Re: David_Trimble]
#665482
04/10/10 11:48 PM
04/10/10 11:48 PM
moparpollack
Lil Herman
Lil Herman
85086
Do yourself a favor and skip the original 4 piston set up. The 73-76 A body set up will mount up as a bolt on and clear your sway bar when you swap spindles side to side. The sway bar mounting changed in 70 to the front and the sway bar mounted thru the k frame. If you do go the route of the 1970 disc brake set up you can get the pins and hardware new.
[Re: moparpollack]
#665483
04/11/10 12:46 PM
04/11/10 12:46 PM
Posts: 738 OK
David_Trimble
OK
Yes I realized that with my pre-70 sway bars that I'll be hitting the caliper, so I'd have to mod the sway bar (which I'd rather not) or hang the calipers on the back. But I thought it was generally 'frowned upon' to swap the calipers to the rear? And if so then how would that affect the steering linkage- wouldn't I have to modify it, too? Yea I'm not considering a 4-piston setup- besides the expense I heard the calipers weren't very easy to maintain. Since the car can never be 'concours-correct' I don't have a problem running the 1-piston setups. Plus I'll have steelies so they'll be hard to see anyway...
