Is a mini starter a worthwhile #665147
04/09/10 12:44 PM
04/09/10 12:44 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Going to be installing my new motor real soon. The old standard starter had no problems, but I'm wondering if now is the time to upgrade to a mini. Car does have headers. It's a street-strip type of effort. I'm not made of money, but $70 could be found. It would just take away from my drag-radial tire budget.
Is this update worth the $$$ ?
Re: Is a mini starter a worthwhile [Re: StealthWedge67] #665148
04/09/10 12:46 PM
04/09/10 12:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You will never go back. Spin faster with less battery draw.
Re: Is a mini starter a worthwhile [Re: MoparforLife] #665149
04/09/10 12:49 PM
04/09/10 12:49 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Head to the junk yard and get one from a late 90's Dakota. $30 well spent. 6 years and still cranking.
Re: Is a mini starter a worthwhile [Re: StealthWedge67] #665150
04/09/10 12:53 PM
04/09/10 12:53 PM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
worth its weight in gold. half the size, half the weight, double the torque.
71 scamp big block with 915 heads 727 trans
Re: Is a mini starter a worthwhile [Re: 71scamp440] #665151
04/09/10 01:06 PM
04/09/10 01:06 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Definetly worth it.Rocky
Chrysler Firepower
Re: Is a mini starter a worthwhile [Re: therocks] #665152
04/09/10 01:28 PM
04/09/10 01:28 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Dump to original and get one. As stated above...You will never go back to the old style starter again....
Re: Is a mini starter a worthwhile [Re: CR8CRSHR] #665153
04/09/10 01:45 PM
04/09/10 01:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You can get one off any 90's dodge v8. I pulled mine off a late 80's/early 90's ram van.
Re: Is a mini starter a worthwhile [Re: DaytonaTurbo] #665154
04/09/10 01:49 PM
04/09/10 01:49 PM
Kenosha, Wi
GOLDMYN Offline
GOLDMYN  Offline
Kenosha, Wi
I just bought a new one from D B Electrical for $75. plus shipping,
Semper Fi
Re: Is a mini starter a worthwhile [Re: GOLDMYN] #665155
04/09/10 02:00 PM
04/09/10 02:00 PM
Eastern North Carolina
riverman Offline
riverman  Offline
Ditto on the DB starter. Have had for 4 years - no problem.
Re: Is a mini starter a worthwhile [Re: riverman] #665156
04/09/10 02:24 PM
04/09/10 02:24 PM
Lynnwood Washington
rp23g7 Offline
rp23g7  Offline
Lynnwood Washington
Ditto on that, mine spins the 440 with ease, although i do miss the characteristic Chrysler starter sound.
Re: Is a mini starter a worthwhile [Re: StealthWedge67] #665157
04/09/10 02:44 PM
04/09/10 02:44 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Well worth it IMO. Being able to access the starter without removing the headers is priceless. The added torque for start up is also a must with performance engines.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Is a mini starter a worthwhile [Re: riverman] #665158
04/09/10 03:23 PM
04/09/10 03:23 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
DB has 2 listed. Both are the same price. What's the difference between the 2?
http://www.db-starter-alternator.com/Starter%20Motors/Mini%20Hi%20Performance/Dodge-Chrysler-Mopar/
Scott
1969 Super Bee, 383/4 speed
Re: Is a mini starter a worthwhile [Re: StukaJU87] #665159
04/09/10 03:57 PM
04/09/10 03:57 PM
scratchnfotraction Offline
one could be a little smaller than the other
I have 2 from the u-pull it for 14$ each
had the first one rebuilt after it started clicking a lot after 2yrs of service,rebuild for 65$ for a total of 79$ on that one..still cheaper than new,been 5yrs now
2nd one from u-pull 14$ was on a 96-97 / v-6 1500 ram
it was smaller and had a plastic plug for the small wire,so I had to splice it into my 85 wire
it had been replace,has a napa sticker on it and was a new one not remaned.. for a total of 14$
spins super fast on the 440 truck
same on the SB,can R&R the starter without R&R of the header on the sb also can R&R the header with out removing the starter with the hedman headers
I miss the sound but not the slow batt killer 30lb ginny that I can barly hold up to the tranz
now the 6lbs mini is a another story...the mini dont hurt as much when you drop it on your head under the car
I will take 6lb knock on the head over a 30lbs one anyday
Re: Is a mini starter a worthwhile [Re: scratchnfotraction] #665160
04/09/10 03:58 PM
04/09/10 03:58 PM
BDW Online content
BDW  Online Content
What about the wiring for a SB?
Do you have to cut up your factory battery cable?
Re: Is a mini starter a worthwhile [Re: BDW] #665161
04/09/10 04:20 PM
04/09/10 04:20 PM
no,not if you get the one with the 2 studs on it,may need to remove an extention piece though..very ez..2 nuts its off
the new one I got had the newr plug deal I did cut and splice the plug into my 85 truck to use it...I moved the one that had 2 studs to the 440 truck cause I did not want to cut the wires up...and I didnt want to go back to the u-pull to exchange it..it was rather new so..I kept it and made due..couldnt beat 14$ for it
I was just say that I notice there was a size diff in the 2 and that the newer one had the plug to deal with so pick the one you need the first time..I should have noticed that when I got it
I upgraded to the mini alt on the 440 in the sig pic also..it wired right up with a couple wire crimps and longer bolt/stock brackets
Re: Is a mini starter a worthwhile [Re: StealthWedge67] #665162
04/09/10 04:25 PM
04/09/10 04:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Make sure your headers will fit around the starter - check the header manufacturer's footnotes. Some headers require specific p/n or model ministarters - TTi's are a good example!
Re: Is a mini starter a worthwhile [Re: Stanton] #665163
04/09/10 05:00 PM
04/09/10 05:00 PM
my hedmans said stock shortolder type starter only
plenty romm for smaller though
Re: Is a mini starter a worthwhile [Re: scratchnfotraction] #665164
04/09/10 08:25 PM
04/09/10 08:25 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
I have a love/hate relationship with mine.
Love the way it cranks over that ol' big block.
Hate the sound - it just doesn't sound like a Mopar cranking over anymore.
Re: Is a mini starter a worthwhile [Re: moparcanuk] #665165
04/09/10 08:38 PM
04/09/10 08:38 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
If you can tolerate the sound. I refuse to use the mini. I have old style starters on everything, and have fired up 12.5:1 engines in the summer AZ heat with ease with the old style starters.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Is a mini starter a worthwhile [Re: scratchnfotraction] #665166
04/09/10 08:41 PM
04/09/10 08:41 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Yea my mini wouldn't clear my cheap hedman's, had to use stock starter.
