Re: 742 clutch type sure qrip fiction modifier & axle pins
[Re: bigblockSfury]
#665104
04/09/10 11:28 AM
04/09/10 11:28 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
You can get a friction modifier at NAPA or carquest that works fine. Thrust pins not needed with green bearings.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#665105
04/09/10 01:22 PM
04/09/10 01:22 PM
Posts: 33 Michigan
bigblockSfury
Music to my ears! Thanks
[Re: bigblockSfury]
#665106
04/09/10 08:49 PM
04/09/10 08:49 PM
Posts: 5,044 At a gas station near you
badblack68
Couple questions:
1) What is the best friction modifier to use and where to obtain it
2) Are the axle "pins" required if you are running green bearings?
I am sorry if these questions seem dumb; I am new to sure grips and am updating from a 2.76 open to 3.23 posi.
Thanks!
What's a posi?
[Re: badblack68]
#665109
04/12/10 09:22 AM
04/12/10 09:22 AM
Posts: 33 Michigan
bigblockSfury
Couple questions:
Thanks!
What's a posi?
Maybe this is a northern Michigan thing...but posi is short for positive traction.
[Re: bigblockSfury]
#665110
04/12/10 10:36 AM
04/12/10 10:36 AM
badblack68
Couple questions:
Thanks!
What's a posi?
Oh ok. That`s a GM or Ford term. In the Mopar world it`s called a sure-grip.
[Re: sthemi]
#665112
04/12/10 12:45 PM
04/12/10 12:45 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
The fresh Dana in my other car has the superstinky Mopar additive, that I belive is now discontinued..or banned by EPA....
I just used some of that in the Dana for my wife's Barracuda. VERY foul smelling indeed! I did not know such a small package could contain that kind of stink!
