What to use to quiet lifters?
#664859
04/08/10 11:08 PM
04/08/10 11:08 PM
Posts: 290 Toronto, ON
ehbody
Toronto, ON
Little noisy, going to be changing oil soon. Is there anything to help? 340
Shawn
70 AAR
Re: What to use to quiet lifters?
[Re: ehbody]
#664860
04/08/10 11:24 PM
04/08/10 11:24 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Rislone,, ATF,,, new cam/lifters..
I am truckless..
[Re: ehbody]
#664861
04/08/10 11:48 PM
04/08/10 11:48 PM
RapidRobert
How many miles, how long have they been noisy? I consider all of the touted snake oil remedies to be just that but several people have sucessfully quieted lifters w Marvel mystery oil. YMMV. Myself I'd take each lifter apart, inspect/clean in solvent/dry/oil/reassemble as their may be dirt in there or 1 or more may be worn out or get another set and redo the cam breakin procedure. Take the valve cover off & w it running press down on each one on the pushrod end w a wooden hammer handle & see if it quiets any of them to ID a bad one. Noisy lifters will eventually just get on your nerves after so long.
[Re: RapidRobert]
#664862
04/09/10 10:51 AM
04/09/10 10:51 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
It depends why it's noisey in the first place. If there is excessive valve lash like from a worn valve train. No additive will compensate for that.
[Re: Dodgem]
#664864
05/06/10 03:25 PM
05/06/10 03:25 PM
ehbody
Toronto, ON
Sorry for the late reply. Engine was done about 5000 ago. The noise goes away after about 15 minutes. I should probably check the adjustments on the lifters.
Shawn
70 AAR
[Re: ehbody]
#664865
05/06/10 03:50 PM
05/06/10 03:50 PM
Challenger 1
Cincinnati, Ohio
Yup, nothing you put in the oil will fix the wrong valve lash.
