What to use to quiet lifters? #664859
04/08/10 11:08 PM
04/08/10 11:08 PM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
Little noisy, going to be changing oil soon.
Is there anything to help?
340
Shawn 70 AAR
Re: What to use to quiet lifters? [Re: ehbody] #664860
04/08/10 11:24 PM
04/08/10 11:24 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Rislone,, ATF,,, new cam/lifters..
I am truckless..
Re: What to use to quiet lifters? [Re: ehbody] #664861
04/08/10 11:48 PM
04/08/10 11:48 PM
How many miles, how long have they been noisy? I consider all of the touted snake oil remedies to be just that but several people have sucessfully quieted lifters w Marvel mystery oil. YMMV. Myself I'd take each lifter apart, inspect/clean in solvent/dry/oil/reassemble as their may be dirt in there or 1 or more may be worn out or get another set and redo the cam breakin procedure. Take the valve cover off & w it running press down on each one on the pushrod end w a wooden hammer handle & see if it quiets any of them to ID a bad one. Noisy lifters will eventually just get on your nerves after so long.
Re: What to use to quiet lifters? [Re: RapidRobert] #664862
04/09/10 10:51 AM
04/09/10 10:51 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It depends why it's noisey in the first place. If there is excessive valve lash like from a worn valve train. No additive will compensate for that.
Re: What to use to quiet lifters? [Re: Magnum] #664863
04/09/10 01:18 PM
04/09/10 01:18 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You can try a liter of ATF add it to the oil and drive a day before oil change. if it still presists on a small block I would look for worn pushrods and maybe rockers. Cheap fix.
Re: What to use to quiet lifters? [Re: Dodgem] #664864
05/06/10 03:25 PM
05/06/10 03:25 PM
Toronto, ON
ehbody Offline OP
ehbody  Offline OP
Toronto, ON
Sorry for the late reply.
Engine was done about 5000 ago.
The noise goes away after about 15 minutes.
I should probably check the adjustments on the lifters.
Shawn 70 AAR
Re: What to use to quiet lifters? [Re: ehbody] #664865
05/06/10 03:50 PM
05/06/10 03:50 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup, nothing you put in the oil will fix the wrong valve lash.
Re: What to use to quiet lifters? [Re: Challenger 1] #664866
05/06/10 04:23 PM
05/06/10 04:23 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
The roller 318 in my truck does the same thing, they tick like crazy for the first 10-15 minutes but after it warms up it's quiet as a mouse. The ticking gets on my nerves but I don't want to have tear into it to replace them. It runs great otherwise.
Re: What to use to quiet lifters? [Re: 440newport] #664867
05/06/10 04:50 PM
05/06/10 04:50 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Exhaust leaks?
Re: What to use to quiet lifters? [Re: ehbody] #664868
05/06/10 09:23 PM
05/06/10 09:23 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
GM additive....E.O.S. can help a noisy lifter tick
Re: What to use to quiet lifters? [Re: radar] #664869
05/06/10 09:25 PM
05/06/10 09:25 PM
crlush Offline
crlush  Offline
make shure you rule out an exhaust leak, I cant believe how many people mistake an exhaust leaks for noisy lifters. Id feel pretty stupid if I changed all my lifters and the exhaust was still leaking.
Re: What to use to quiet lifters? [Re: crlush] #664870
05/06/10 10:06 PM
05/06/10 10:06 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
pint of transmission fluid in the oil works as well as the high priced additives.
Re: What to use to quiet lifters? [Re: MoparforLife] #664871
05/06/10 10:31 PM
05/06/10 10:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
May just be CHEAP lifters. My local engine builder uses them, I hate them, We've had several comebacks on "rebuilt" motors. No other issues than exactly what you describe. We've swapped in several sets of Quality lifters IE: comp cams. and the issue goes away. I 'm trying to convince the builder but he's not listening and i am looking for another builder.
Re: What to use to quiet lifters? [Re: TJP] #664872
05/07/10 12:06 AM
05/07/10 12:06 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
Over time a spring with high seat pressure will squeeze the oil out of the lifter. This causes the rod to be a tad loose at start up. Once the oil psi has evened the lifter pintles, and filled. The engine should stop ticking for those first few minutes.
To avoid this use cams with less lift/spring pressures on a hydraulic lifter .
