how to id a hemi 4 spd.... #664688
04/08/10 08:17 PM
04/08/10 08:17 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
...with no input shaft.Any sugestions?
Re: how to id a hemi 4 spd.... [Re: crowbait] #664689
04/08/10 08:25 PM
04/08/10 08:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Does it have a VIN on it?
Re: how to id a hemi 4 spd.... [Re: Alaskan_TA] #664690
04/08/10 08:33 PM
04/08/10 08:33 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
1-2-3 speed gears are bushed. You could also get tooth counts on the gears and cluster.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: how to id a hemi 4 spd.... [Re: Alaskan_TA] #664691
04/08/10 08:34 PM
04/08/10 08:34 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Im not sure,I did not go look at it yet.
Re: how to id a hemi 4 spd.... [Re: crowbait] #664692
04/08/10 09:03 PM
04/08/10 09:03 PM
IMGTX Offline
IMGTX  Offline
IIRC it will have a large 308 input bearing and the gearsets will be bushed. If it has the input bearing retainer it will be larger than the 23 spline one. I can get measurements if you need tomorrow.
Re: how to id a hemi 4 spd.... [Re: IMGTX] #664693
04/08/10 09:15 PM
04/08/10 09:15 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
66-7 Hemi trans used 307 brgs and the small 4.354" bearing ret.
Re: how to id a hemi 4 spd.... [Re: Dan Brewer] #664694
04/08/10 10:16 PM
04/08/10 10:16 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
thanks guys
