mags oil thru the roller lifter/pushrod to the rockers
pushrods are hollow,correct????
check you lifters,I had a few apart on mine and they had a good amount of carbon/grit/dirt??? in them,some were pumped up solid and stuck with a lot of gunk in them..sorrta made it a solid lifter
high milage used ones,they had a tick to them before I opend and cleand them all
now they are good to go and no ticks
took a few mins of run time..maybe 10 mins to get the air completly pumped out on fire up with the new roller cam
cleaned all 16 and they were dry till I primed and did the fire up
