Re: Challenger steering - lower bearing install help
[Re: conv440]
#664640
04/08/10 09:14 PM
04/08/10 09:14 PM
Posts: 21,503 It's a dry heat
gtx6970
It's a dry heat
Thanks, do you know if the correct one is available?
![](http://amhightechauto.com/images/parts/C29.JPG)
[Re: conv440]
#664650
04/08/10 11:43 PM
04/08/10 11:43 PM
Posts: 1,066 California
70SportSatellite
super street
super street
California
Can I just mail my car up to you and have you set it right
Maybe I can help. What I did was make a bushing out of plastic round bar. I drilled it to the shaft size and turned it down so it fit in the tube. I also stepped it.Then I cut it in half. When installing the column attach the lower support plate to the bottom of the dash with the nuts on the studs then attach the coupling. IIRC there is a set depth for the shoes in the coupling housing but I don't have it handy. I could be wrong but I thought there was a line on the shaft that goes flush with the housing. After the depth is set tighten the nuts on the studs. Now slip the 2 piece bushing in place and this centers the shaft in the tube. I used a hose clamp to hold it together. Now tighten the lower column support plate to the firewall. This is why the holes are so large. Remove alignment bushing and you have it.
[Re: conv440]
#664652
04/09/10 07:16 AM
04/09/10 07:16 AM
Challenger 1
Cincinnati, Ohio
I know you are working on a 70 car, 74 E bodys had a lower ball bearing with bearing holder down there. This is the upper bearing. You can see the lower bearing holder, bearing and retainer spring in this picture. I was able to get the bearing from Mopar in 05, the holder was NA. I put this setup in my 71 car, my 74 already had it. I have another set that's going in my other 74 when I get it done. FYI ![](http://i21.photobucket.com/albums/b260/challenger19711/Phase%20II/MVC-266S.jpg) I have the part number for the lower bearing somewhere, just don't have it here at work. Another shot of the 74 lower bearing support and bearing.
[Re: JulesdaWiperman]
#664654
04/09/10 08:16 AM
04/09/10 08:16 AM
Challenger 1
Cincinnati, Ohio
That's right Gary. Now the head scratch question of the day is why did they go to a metal encased bearing in 74 when back in 68-69 b bodies they used a nylon captured bearing? I have a few theories. Yours? Jules
Jules, I have no clue. What are your thoughts? Thanks
