door glas b-body #664559
04/08/10 05:53 PM
04/08/10 05:53 PM
S.E. Wis
a4runer Offline OP
a4runer  Offline OP
S.E. Wis
After 4+ years putting the RR together and can not remember how to put the front door glass in.I have the vent window and cat whiskers in door but can not remember if I can just force the front glass with plastic into the channel on the vent window or is something else involved. Did this stuff 40 yrs ago but for some reason I can not recall anymore........Thanks Bruce
Re: door glas b-body [Re: a4runer] #664560
04/08/10 07:36 PM
04/08/10 07:36 PM
NJ
rth Offline
rth  Offline
NJ
take vent frame back out .glass gets install from bottom of long track and installed as one unit.line up with rear track.tape all painted surfaces and get a extra set of hands.
Re: door glas b-body [Re: a4runer] #664561
04/08/10 07:38 PM
04/08/10 07:38 PM
okla.
O
okie Offline
okie  Offline
O
okla.
There is 2 small screws at the top of the vent glass frame, one holds the small rubber stop on and the other is below it and holds the frame together. Take them both out and you can pull the uprite over enough to slid your glass in then put it back together. Good Luck! Ronnie
Re: door glas b-body [Re: okie] #664562
04/08/10 09:52 PM
04/08/10 09:52 PM
Delaware shore
68Barracuda Offline
68Barracuda  Offline
Delaware shore
Just did mine last weekend just as Ronnie suggested it worked for me.
Re: door glas b-body [Re: a4runer] #664563
04/09/10 07:16 AM
04/09/10 07:16 AM
S.E. Wis
a4runer Offline OP
a4runer  Offline OP
S.E. Wis
Thanks all I will give it a try this morning.I had to walk away in frustation yesterday...Bruce
