Dad has an Intrepid that needs a cam and crank sensor. He took it to the dealership for diagnostics and was just told that is the problem.
When the car gets up to opperating temp,and it's warm outside, the engine misses and bucks pretty bad while going down the highway. I thought it was going to leave us stranded more than once.
How accessible are those sensors? Can I easily do that myself or is it a pain to get to? The dealership wants $400 to install them. The car has close to 210,000 miles on it so spending that kind of money on it is rediculous. I thought about going to a yard and pulling some used sensors out of another car if it was easy to get to.
Also, the oil sending unit is leaking. Is that a straight forward fix in that car or a pain? Thanks
