Dodge tech help trouble code P0171/P0300 #664478
04/08/10 03:25 PM
04/08/10 03:25 PM
NY usa
540challenger Offline OP
NY usa
I have a 97 dodge van 5.2L 2 trouble code came up.
The van started to buck and back fire.
P0171 Soleniod circuit range performance bank 1
P0300 muilt cylinder misfire
I was looking at the operation data and i found that 1 of the o2 senors was only read .200volts and not fluctuating.
If iam think correctly the O2 is bad and reading lean and the computer is riching the mixture to compensate.
I am i correct or should i be looking some where else.
Re: Dodge tech help trouble code P0171/P0300 [Re: 540challenger] #664479
04/08/10 04:56 PM
04/08/10 04:56 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Cyl. misfire will cause an O2 to read lean(not burning the O2) as will a vacuum leak(excess O2)check secondary ignition, etc first to locate misfire issue.
