hughes rocker hold down kit ? #664474
04/08/10 02:49 PM
04/08/10 02:49 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
just got mine in the mail. looks like i'll have to mill the sides down quite a bit. i'm running comp pro magnum rockers and stealth heads. about how much did you have to shave off the sides? also, the studs seem too short, if i screw them in finger tight, the nut is only about half on and that's without using the supplied washers. should i just not fully seat the studs and not use the washers? what do moparts members think? thanks.
Re: hughes rocker hold down kit ? [Re: dirtybee] #664475
04/08/10 03:40 PM
04/08/10 03:40 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Call and get advice from Dave or Kevin. That way if something goes wrong they can't say that you didn't contact them first.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: hughes rocker hold down kit ? [Re: dirtybee] #664476
04/08/10 04:14 PM
04/08/10 04:14 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Yes you will have to "size" them to fit your heads..no I can't say how much because yours are different than mine,etc. I believe there is two different length studs for different holes in the heads. Mine worked fine but mine are on Eddy heads,not sure on the Stealths,I'm sure someone will chime in here!
Re: hughes rocker hold down kit ? [Re: Dcuda69] #664477
04/08/10 06:14 PM
04/08/10 06:14 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
just got back from the shop and managed to get one head done. it ended up at about .045" per side on each hold down for a total of .090" off each piece. i really like that they include tons of side shims to dial in your specific needs. nice kit. oh i also tacked in the end plugs on my comp rocker shafts with a tig after one blew out on me, hopefully my valvetrain is solid now . maybe this info can help out someone
