383 Header Suggestions needed #664400
04/08/10 12:10 PM
04/08/10 12:10 PM
Northern NJ
StukaJU87 Offline OP
Northern NJ
Please consider that my car is pretty much a stock 69 b body wagon with a 383/727. I have decided on using the Dynomax side pipes for the car and would like to put on a half decent set of reasonably priced (budget minded, this car will never be raced, just street driven) headers that don't require removing the starter AND will fit with power steering.
Also, there is always the chance that this motor will be freshened up next season or possibly a 390hp 383 from Maund.
Can you guys give me some suggestions on long or short headers that might do the job?
Scott
1969 Super Bee, 383/4 speed
Re: 383 Header Suggestions needed [Re: StukaJU87] #664401
04/08/10 12:34 PM
04/08/10 12:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Summit headers $109. They are the same as heddmans I think.
Re: 383 Header Suggestions needed [Re: Mr.Yuck] #664402
04/08/10 03:40 PM
04/08/10 03:40 PM
Northern NJ
Northern NJ
The instruction sheet says you have to remove the starter to install these. Is that so? I had a set of BlackJack headers on a 440 Challenger years ago that burnt up 2 starters because they were so close to it. I finally got sick of it and went to HP manifolds. Pulling the header to change the starter is a pain. Any ideas?
Scott
Post deleted by moparts [Re: StukaJU87] #664403
04/08/10 03:47 PM
04/08/10 03:47 PM
Re: 383 Header Suggestions needed #664404
04/08/10 04:38 PM
04/08/10 04:38 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
hedman elites. ceramic coated, thick tube, thick flanges, and ~ $350. IIRC they go over the centerlink, too.
I wish they made a small block version.
2017 Grand Cherokee Overland
Re: 383 Header Suggestions needed [Re: patrick] #664405
04/08/10 06:43 PM
04/08/10 06:43 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
I have fabricated shields which worked fine, and I also wrapped one starter with asbestos cloth. Worked great! Got a whole roll, so when it gets grungy I can put another piece on. But a tin or aluminum shield is probably better, if you can do it.
Re: 383 Header Suggestions needed [Re: 4BBodies] #664406
04/08/10 08:10 PM
04/08/10 08:10 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
How about the Hedman shorties? I don't think you'd have a problem with anything with them, even though they aren't a full lenght header.
Re: 383 Header Suggestions needed [Re: StukaJU87] #664407
04/08/10 08:21 PM
04/08/10 08:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used a mini starter I jacked the car up. Jacked the drivers side up and they went i from the bottom. Pass side is easy. If you want good headers get a set of hooker super comps
Re: 383 Header Suggestions needed [Re: Mr.Yuck] #664408
04/09/10 12:58 AM
04/09/10 12:58 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Summit is now offering ceramic coated "Summit Brand" headers. Think they're $250-ish.
Re: 383 Header Suggestions needed [Re: StealthWedge67] #664409
04/09/10 06:18 AM
04/09/10 06:18 AM
scratchnfotraction Offline
mini starter is a good upgrade and drops 25lbs off the moder
fit way better with headers
I can r&r the mini starter on my sb with hedman truck headers in place
cant do it with the stock one.and it has to be the shorter stock starter also to just fit
the mini starter on my 440 in the 88 truck spins it over very fast and fires up with a fast flick of the key
IMHO,whatever header you use a mini starter only makes it better for any service to be done on it
Re: 383 Header Suggestions needed [Re: stubbs300 ] #664410
04/09/10 08:27 AM
04/09/10 08:27 AM
Northern NJ
Northern NJ
BINGO, they look like just what I need. Looks like part # HED-78070. I think they'll be great with the side pipes and yes, I'll do a mini starter when I do the exhaust.
The car is at the shop now getting the front end rebuilt. Soon as I get it back, I'll measure for the side pipes and order up the headers, pipes and starter.
Thank you ALL for your help!
Scott
Re: 383 Header Suggestions needed [Re: StukaJU87] #664411
04/09/10 10:28 AM
04/09/10 10:28 AM
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Sweet!! Glad that I helped you make your decision so easy.
