383 Header Suggestions needed
#664400
04/08/10 12:10 PM
04/08/10 12:10 PM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
Please consider that my car is pretty much a stock 69 b body wagon with a 383/727. I have decided on using the Dynomax side pipes for the car and would like to put on a half decent set of reasonably priced (budget minded, this car will never be raced, just street driven) headers that don't require removing the starter AND will fit with power steering.
Also, there is always the chance that this motor will be freshened up next season or possibly a 390hp 383 from Maund.
Can you guys give me some suggestions on long or short headers that might do the job?
Scott
1969 Super Bee, 383/4 speed
Post deleted by moparts
[Re: StukaJU87]
#664403
04/08/10 03:47 PM
04/08/10 03:47 PM
Re: 383 Header Suggestions needed
#664404
04/08/10 04:38 PM
04/08/10 04:38 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
hedman elites. ceramic coated, thick tube, thick flanges, and ~ $350. IIRC they go over the centerlink, too.
I wish they made a small block version.
[Re: StukaJU87]
#664407
04/08/10 08:21 PM
04/08/10 08:21 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Summit headers $109. They are the same as heddmans I think.
The instruction sheet says you have to remove the starter to install these. Is that so? I had a set of BlackJack headers on a 440 Challenger years ago that burnt up 2 starters because they were so close to it. I finally got sick of it and went to HP manifolds. Pulling the header to change the starter is a pain. Any ideas?
I used a mini starter I jacked the car up. Jacked the drivers side up and they went i from the bottom. Pass side is easy. If you want good headers get a set of hooker super comps
[Re: Mr.Yuck]
#664408
04/09/10 12:58 AM
04/09/10 12:58 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Summit is now offering ceramic coated "Summit Brand" headers. Think they're $250-ish.
[Re: StealthWedge67]
#664409
04/09/10 06:18 AM
04/09/10 06:18 AM
Posts: 15,487 Florida
scratchnfotraction
mini starter is a good upgrade and drops 25lbs off the moder fit way better with headers I can r&r the mini starter on my sb with hedman truck headers in place cant do it with the stock one.and it has to be the shorter stock starter also to just fit the mini starter on my 440 in the 88 truck spins it over very fast and fires up with a fast flick of the key IMHO,whatever header you use a mini starter only makes it better for any service to be done on it
[Re: StukaJU87]
#664411
04/09/10 10:28 AM
04/09/10 10:28 AM
Posts: 1,181 Lost in the ozone again
stubbs300
Vacation
Vacation
How about the Hedman shorties? I don't think you'd have a problem with anything with them, even though they aren't a full lenght header.
BINGO, they look like just what I need. Looks like part # HED-78070. I think they'll be great with the side pipes and yes, I'll do a mini starter when I do the exhaust.
Thank you ALL for your help!
Sweet!! Glad that I helped you make your decision so easy.
