Re: Carbureted Magnums
[Re: dmerc]
#664367
04/08/10 05:30 PM
04/08/10 05:30 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
If you use a M-1 Dual plane it has a provision for running coolant through the manifold. Mine works good! And you can run leaner mixture which will net better gas mileage. Not the best for all out performance though.
Yep, that is one of the little known features of the M1 dual plane for magnum heads. It's an unusual piece that way.
[Re: ZIPPY]
#664368
04/08/10 08:59 PM
04/08/10 08:59 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
I run that set up with the water running through the plenum area. Problem is it takes about 8 - 10 minutes in cold weather to warm up the intake and warm up the air/fuel mixture. No choke and an open style air filter.
One interesting thing is my water is warm in about half that time, but it's not bog free until way later.
It's 100% most definately the cold intake. I have a capilary style coolant heater. Since it's plumbed up through that plenum passage. I can make it very warm yet the engine itself is still cold. With that situation, the truck drives totally bog free even though the rest of it is cold.
[Re: Magnum]
#664369
04/08/10 09:48 PM
04/08/10 09:48 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I've got an '86 318 roller cam short block, cam reground by bullet with their HR259/316 lobe for int & ex, hughes 1110 springs, 2.2L retainers, mag heads, headers, eddie RPM air gap, and eddie 1406 600cfm elect. choke. runs fine year round in michigan, gets a little cranky on cold mornings below 15 degrees or so until it's warm.
I strongly suggest this cam, doesn't need roller rockers. mine's going fine with stock mag lifters, pushrods, and rockers.
[Re: stryker63]
#664371
04/09/10 12:10 AM
04/09/10 12:10 AM
DaytonaTurbo
Manitoba, Canada
I put 440source stealth heads on my 440. Left the stock cast iron intake on there. So the heads are aluminum but unlike stock heads, they don't have the heated exhaust crossover. I did notice it takes 5 minutes longer for the choke to open now on a cold day than it did before. I run a thermoquad, stock choke without the electric assist part hooked up, just the stock thermostatically operated coil running the choke. I know it takes about 5 minutes longer because I drive the car to work daily and I'm closer to work by the time the choke fully opens and it drops to base idle speed at a stop. Cold driveability is no worse really, just have to drive that extra few minutes before the choke fully opens and I can feel it's warmed up. I bet if I had an aluminum intake on it, the choke would open up faster just because the aluminum will heat up quicker from engine heat than the cast iron. It's usually in the -10 to -15*c range before I pack it away for the winter. Once the intake has warmed up, it's just as fine running as it was before.
[Re: fox]
#664374
04/10/10 12:35 PM
04/10/10 12:35 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Could have more problems with humidity than I do, we have very little here but it never frosts up.
[Re: HotRodDave]
#664375
04/10/10 12:36 PM
04/10/10 12:36 PM
HotRodDave
Kalispell Mt.
Another thing you might be able to do is fab up a heat stove to feed it some warm air from the exhaust.
[Re: stryker63]
#664376
04/11/10 09:25 PM
04/11/10 09:25 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have a 360 magnum with an air gap manifold, headers, electric choke 600 holley...and its low compression and stick. The car will stay running just fine but hesitates a little until its warm. You'll have to leave the choke on longer than you normally would, but it runs good enough to drive right away.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
