How do you figure a cams centerline?
#664240
04/08/10 01:36 AM
04/08/10 01:36 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
my cam card gives info on lift, duration both at .050 and running, and valve opening and closing points. What is the formula for taking this info and figuring the centerline?
Re: How do you figure a cams centerline?
[Re: StealthWedge67]
#664241
04/08/10 08:57 AM
04/08/10 08:57 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
post the opening and closing points. Intake installed centerline + Exhaust installed centerline / 2 = Cam LSA (centerline).
So if the intake is to installed 106 ATDC and exhaust is to be installed 114 BTDC 106 + 114 = 220 / 2 = 110 Lobe separation angle (cam centerline)
#664244
04/08/10 04:49 PM
04/08/10 04:49 PM
Posts: 1,200 UK
602heavy
UK
Are you asking for the lobe seperation angle or the installed intake centreline? , these #s will usually differ around 4*.
