small block oiling question #664190
04/07/10 10:39 PM
04/07/10 10:39 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
i just had my motor freshened its a R3 block bushed lifters pushrod oiling with t&d(jesel)type rockers.i primed the oiling system i have 70psi with a cordless drill.Heres my possible issue maybe nothing but rather ask when i have the valve covers off the #8 rockers getting major oil the others not alot.Drivers side head has bearly any oil getting to rockers 4 have oil coming out but not strong.ive tryed to turn engine and crank engine still not alot coming out if any on drivers side.is this normal should i get the engine running like this?
Re: small block oiling question [Re: demon454] #664191
04/07/10 11:08 PM
04/07/10 11:08 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
With push rod oiling the only way to get oil to the driver's
side oil galley, is through the passage from the passenger side
galley, down to #1 main, then back up to driver's side.
BTW, #8 is the closest to the pump.
It could be you are not producing enough volume with the drill.
I'm assuming the oil passages was clean, when it was assembled.
Re: small block oiling question [Re: S/ST 3040] #664192
04/07/10 11:21 PM
04/07/10 11:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
I shouldn't have said, "With push rod oiling......"
Unless the block has been modified with a "cross-over", through the
#1 main is how they all get oil to the driver's side.
Re: small block oiling question [Re: S/ST 3040] #664193
04/07/10 11:32 PM
04/07/10 11:32 PM
usa
demon454 Offline OP
demon454  Offline OP
usa
you maybe right the longer i primed i started to get oil on drivers side but not as much as pass.im used to the factory single shaft oiling through the head.
