THAT'S IT. I'VE HAD IT WITH THIS FUEL PUMP
#664153
04/07/10 10:11 PM
04/07/10 10:11 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
So, earlier, I had good pressure and no leaks and I was feeling pretty good.
took time out to change the plugs and wires on Gina's mini van and then go to double check the pressure at the regulator as well as show dad all was good and I have no pressure at all and it's making a awfull noise
Make sure their was fuel in the cell and there was. Even added a little just to be safe.
Try again and no change.
Drain the cell and take it all apart again. Rotor seized to the shaft and little metal dust all over
Tomorrow I'm going and picking up the MF. I'm done with this one
Try agian
Re: THAT'S IT. I'VE HAD IT WITH THIS FUEL PUMP
[Re: WILD BILL]
#664154
04/07/10 10:23 PM
04/07/10 10:23 PM
[Re: ]
#664155
04/07/10 10:25 PM
04/07/10 10:25 PM
WILD BILL
BROOK PARK, OH
[Re: WILD BILL]
#664156
04/07/10 10:27 PM
04/07/10 10:27 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
It was a BG 400-2
That's what I run Bill 400-2 (titanium) it's been working well for two years now....sorry to hear your having problems, but I do believe if your going to stay with that style pump you really need to mount it vertical
Rickster
[Re: sixpakdodge]
#664159
04/07/10 11:55 PM
04/07/10 11:55 PM
WILD BILL
BROOK PARK, OH
Is this the one you bought cheap at a swap meet?
Yes it was. And for a while I thought I got a deal.
I probably wouldn't near as upset about it had it not worked fine just a couple hours earlier
After this and the carb that wasn't what it was supposed to be it'll be a long time before I buy something of the sort at a swap meet again.
[Re: WILD BILL]
#664161
04/08/10 12:14 AM
04/08/10 12:14 AM
I agree with you on that one, just not worth it with a lot of the used parts.
[Re: WILD BILL]
#664163
04/08/10 07:12 AM
04/08/10 07:12 AM
Challenger 1
Cincinnati, Ohio
Try agian
Sorry...Bummer, don't BG pumps have a history of leaking?
I don't think the mounting positon has anything to do with the leak.
[Re: Challenger 1]
#664164
04/08/10 07:30 AM
04/08/10 07:30 AM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
why not send it to BG and have them rebuild it???
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: StripeHOG]
#664165
04/08/10 07:43 AM
04/08/10 07:43 AM
Posts: 4,984 new jersey usa
11secdart
new jersey usa
Thats why we call his parts " Barry Can`t"
[Re: WILD BILL]
#664166
04/08/10 07:54 AM
04/08/10 07:54 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill... are you pumping alky now... are you running a top end lube....... I've never been a fan of BG stuff.... sorry too hear it didnt want to play... its a never ending story
[Re: 3ddart]
#664170
04/08/10 10:45 AM
04/08/10 10:45 AM
WILD BILL
BROOK PARK, OH
Better ? is why won't they send me the parts so I can do it my self? I'm not going to support their buisness practice of not sending out repair parts
And I'm not one to push my junk on anyone else. I know you know me better than that.
[Re: WILD BILL]
#664171
04/08/10 10:51 AM
04/08/10 10:51 AM
Posts: 19,368 Las Vegas
Al_Alguire
Las Vegas
Well I have been using a BG400 for a few years. I did have one leak once when the car sat for a few months and I did not drain the tank. Put in a new seal and it works fine again. Unfortunately due to not being able to get a seal quickly I ended up buying a second pump. Now I have a spare, that works fine. As for them not selling the parts, I can sort of understand that. I mean if it were to be improperly repaired and leaked everyone will bad mouth the piece and therefore the manufacturer, just my Mallory also does not sell the parts to repair thier pumps or regulators as well. I have used them in the past and had them rebuilt by Mallory with no issues. I would be willing to bet most companies do not sell repair parts for their products for the same reason. Also how can you condemn the pump maybe it was a defective seal??? FWIW it is the same seal and o ring arrangement as Magnafuel, and PE as well. Just saying....
[Re: WILD BILL]
#664172
04/08/10 11:32 AM
04/08/10 11:32 AM
rickstershemi
Bill the original 400-2 that came in the roadster was an Alky setup. It had sat for a couple of years and they never drained the tank, I flushed it all out good and when I fired up the new bullet on gas it never leaked, but the 1st time at the track it would lose pressure after the hit....ended up pulling it apart and the inside of the pump was all corroded from sitting for so long with alky in it, but it never did leak, my system is set up per BG's instructions and as said previously haven't had a problem with the new one and it sits for months at a time with fuel in it
I would send it in and let them rebuild it, IMHO, they really are a good pump
I also understand them not wanting them worked on by anyone else, but do think they should supply additional gaskets with instructions when you buy a new one just in case, not everyone can afford to have a spare sitting on the shelf
Rickster
