eingine diaper and oil pan -kinda long #664144
04/07/10 10:04 PM
04/07/10 10:04 PM
Ohio, U.S.
73-Dart-sport Offline OP
Ohio, U.S.
I have about a 1/4 inch gap between my headers and the oil pan. Russeleri says I need about an inch of space. I will have to either have a header bent differently or modify the oil pan. Russeleri suggested that the back corner of the oil pan be cut on a 45 degree angle and a new piece of metal welded in. What do you all think? Any ideas or if you can comment from experience, it would be helpful. Which do you think would be the easier modification? Will the modification to the oil pan possibly cause oiling issues? The car has a 400 block and a Milodon oil pan. The oil pan is the one with the sump in the middle. I think the headers are Proparts (Prosport- is this right?) Thanks in advance for any ideas. I would really like to run with an engine diaper for safety reasons.
Re: eingine diaper and oil pan -kinda long [Re: 73-Dart-sport] #664145
04/07/10 10:11 PM
04/07/10 10:11 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
I say run-it as-is ...with the diaper that close. B U T use some asbestos to protect the diaper from the header-heat.
Re: eingine diaper and oil pan -kinda long [Re: 73-Dart-sport] #664146
04/08/10 07:24 PM
04/08/10 07:24 PM
Ohio, U.S.
Ohio, U.S.
Anybody else have some advice? Somebody has to have had similar issue in the past. Thanks.
Re: eingine diaper and oil pan -kinda long [Re: 73-Dart-sport] #664147
04/08/10 10:55 PM
04/08/10 10:55 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
When DRE made mine, they just lined it with a heat resistant (aluminized?) section where it passed close to the headers..
Post deleted by Defbob [Re: Kevins493] #664148
04/08/10 11:00 PM
04/08/10 11:00 PM
Re: eingine diaper and oil pan -kinda long #664149
04/08/10 11:05 PM
04/08/10 11:05 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Sorry, i misread his post. I thought he had 1 1/4".
Re: eingine diaper and oil pan -kinda long [Re: Kevins493] #664150
04/11/10 12:49 PM
04/11/10 12:49 PM
Ohio, U.S.
Ohio, U.S.
Thanks to those that replied. I talked to Russel at Russeleri and he is going to do the diaper with a heat material that will go over the corner of the diaper near the oil pan. It will withstand heat up to 1200 degrees. I also intend to attach a small thin piece of metal against the header which will act as a heat shield to the thin material in that corner of the diaper. I will let everyone know how it works.
Re: eingine diaper and oil pan -kinda long [Re: 73-Dart-sport] #664151
04/11/10 01:26 PM
04/11/10 01:26 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Keep us posted Dave. If the material gets oil on it, it will become more of a fire hazard so you'll have to keep an eye on it. Your headers are MadDogs by the way.
Re: eingine diaper and oil pan -kinda long [Re: 73-Dart-sport] #664152
04/11/10 02:12 PM
04/11/10 02:12 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
This may not seem like the greatest idea, LOL But could you possibly run some spacers between the head and headers to push them out? I know a-bodies don't have much room.
