Re: dual point distributor
[Re: TrueTripleX]
#664082
04/07/10 09:05 PM
04/07/10 09:05 PM
RapidRobert
I'm assuming Pertronix doesn't offer an electronic conversion for a dual point? I've heard people have been able to make them run pretty stout. Your limited by the amperage the points can pass. I'd find the best point sets you can locate and experiment w lesser ohms on the ballast along w a hotter coil (ohms/turn ratio)
[Re: chewy]
#664089
04/08/10 10:44 AM
04/08/10 10:44 AM
Posts: 5,268 NY
70440+6bbl
NY
My .02, if you want to keep the stock look, why not just keep it stock. The dual-point is hotter ignition than single point, it is consistent, and IMO, fairly low maintenance for points.
I used to feel the need to change all of my points cars over to electronic ignitions because I thought it was a necessity after hearing horror stories about points, well after a long battle trying to figure out why my Cuda was running like crap and giving me fits with the MP kit that was installed by a previous owner years ago, I went to a stock prestolite, set it up with NOS points/condenser,cap and rotor, and the car has never driven so nicely since I have owned it Points are not voodoo, and once set correctly, they are super reliable. I doubt I will ever experience points bounce on this set-up, so that is not an issue. I even tossed a spare set of new points in the glovebox just in case, try that with the Pertronix or MP distributors on a Sunday cruise
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
