440 miss above 5000
#66394
05/30/08 09:46 PM
05/30/08 09:46 PM
Posts: 60 Smith Mtn Lake, VA
karls67gtx
Smith Mtn Lake, VA
I am having a small issue with my 440 missing above 5000 rpm. It is in a 67 GTX with a 5 spd tranny. I have 10 3/4:1 comp, a solid cam with 242/252@ .50, heddman headers, performer RPM, 750 holley with proform main body, pertronix ignition and flamethrower coil. I just recently had the motor out doing some detail work and the only thing i did with the engine was adjust the valves. It seems to run hard up to 5k and then acts almost like a rev limiter and misses. Once I shift it seems to be fine. I have checked the carb and the secondarys seem to be working fine. i guess my question is, is this an ignition issue (double checked and the pertronix is getting 12v)or could a valve be hanging open or floating? I'm pretty sure it didn't do this when I pulled it out last fall. thanks for any help you might provide. -karl
Mopar Man
Re: 440 miss above 5000
[Re: karls67gtx]
#66396
05/31/08 01:48 AM
05/31/08 01:48 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Sounds like valve float. I think you can confirm or rule it out on a vauum gauge if you try. Run it out the from under the hood, to under the wiper, and tape it down. (sounds a little hill billy, I know ...) If you see it really bounce down on the miss (like a big drop) it's likely because the intake valves are floating and burbing compression back into the intake. No matter what the miss is, it will move, but the affect will be dramatic with a valve float/bounce.
[Re: karls67gtx]
#66397
05/31/08 02:10 AM
05/31/08 02:10 AM
RapidRobert
rotor phasing or fuel starvation
[Re: RapidRobert]
#66398
05/31/08 04:47 AM
05/31/08 04:47 AM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
Did you reinstall a block to chassis ground? My sons high rpm miss was because he failed to do so.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: GTX70sixpack]
#66399
06/04/08 05:17 PM
06/04/08 05:17 PM
karls67gtx
Smith Mtn Lake, VA
Double checked the ground and we are good there. I have felt fuel starvation before and this is a lot different. It would fall flat on it's face when I had fuel starvation, right now it just misses a little (even in first gear) at 5k and then will not pull anymore. I guess I am leaning at gettting some new valve springs, thanks for the help. BTW, what is rotor phasing? thanks -karl
Mopar Man
