SPRING PRESSURE ON MOPAR .590 CAM #663835
04/07/10 06:37 PM
04/07/10 06:37 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
i have got RPM springs with inners for my old motor which had a R280 roller cam, is this too much and if so, will the RPM springs without the inners be sufficent.
Mick
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663836
04/07/10 06:56 PM
04/07/10 06:56 PM
organ
maximum entropy Offline
organ
that would be too much with the inners imo. that cam is next on my list, and i'm going to run it with a fresh set of rpm springs. i've had very good luck with those springs on similar cams.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663837
04/07/10 09:25 PM
04/07/10 09:25 PM
NC
440Jim Offline
440Jim  Offline
NC
Depending on valve train weights (including valves), and desired RPM, roughly 135 lbs seat and 370 lbs open is in the ball park.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663838
04/07/10 09:27 PM
04/07/10 09:27 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I ran the Isky 8005a springs with the 590 cam with good luck, also used 1.6 rockers.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: ProSport] #663839
04/07/10 09:43 PM
04/07/10 09:43 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
We run Comp #928 springs with that cam,using the stock Edelbrock installed height.The are a direct swap for the stock Edelbrock springs.It is a good idea to upgrade the retainers and locks,but you probably already did with a roller?
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: Dunnuck Racing] #663840
04/08/10 05:30 PM
04/08/10 05:30 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've just checked the springs they are 190 seat, stock eddy valves, isky 1.5 solid rockers.
I dont really want to buy another set as i also need new push rods, a converter and a new set of slicks and the money is running out.
I've got a spare set of brand new stock eddy springs, they claim they are good to .600 lift on their website.
I will shift at 6200 and maybe 6700 or so through the 1/4 mile.
prosport
I cant find them on isky's website, do you know what spring pressure they are.
Mick
4.56 gears and 31" slicks.
Mick
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663841
04/08/10 08:40 PM
04/08/10 08:40 PM
NC
440Jim Offline
440Jim  Offline
NC
prosport
Mick
Mick
IMO, the springs you have will risk wiping the solid lifter cam. With only 6700, you might be fine with 340 open, but I still like 130-140 seat.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: ProSport] #663842
04/08/10 09:03 PM
04/08/10 09:03 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
thats what i use. i think they are about 400lbs open .
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: 493_DART] #663843
04/08/10 10:29 PM
04/08/10 10:29 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I have them also. But, I dont think they are near 400 open, more like 330-350.
Looks like they are 135 on the seat at 1.875.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: Von] #663844
04/09/10 11:18 AM
04/09/10 11:18 AM
NC
440Jim Offline
440Jim  Offline
NC
From Isky web site:
http://www.iskycams.com/springbook.pdf
125 at 1.900"
145 at 1.850"
So at 1.88" that would be about 133 lbs seat
And at 0.590" lift from 1.88, ie 1.29" open
365 at 1.300"
385 at 1.250"
So at 1.29" that would be about 361 lbs open
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: 440Jim] #663845
04/09/10 02:49 PM
04/09/10 02:49 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I'm going to try the edelbrock singles, i currently run 29.5 slicks with a 4.56 gear but I'm fitting 31" slicks to keep the revs down a little.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663846
04/09/10 03:10 PM
04/09/10 03:10 PM
Mick, check the open pressures(all of them) on those roller springs. I would break in the cam in with the Eddy springs and then, if the open pressues is not over 400 lbs, swap the roller springs into the motor. I run 165 to 190 lbs. on the seats and shoot for 375 to 425 lbs open, but you should absolutely break the new cam in with less pressures
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: Cab_Burge] #663847
04/09/10 03:51 PM
04/09/10 03:51 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
HI Cab
The cam is already broken in and the heavier springs are still on at the moment, i've just clayed the heads again and the clearance seems ok, just need some longer puhrods and i will finish putting it together.
I've also got a .625 herbert roller i might try later, just want to try the .590 first to see if it deserves it's reputation.
Mick
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663848
04/09/10 03:54 PM
04/09/10 03:54 PM
Mick
Good luck Mick, is this one of the early "590" with .590 net lift at the retainers with the lash set or one of the later ones that doesn't have .590 net lift at the retainers?
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: Cab_Burge] #663849
04/09/10 04:58 PM
04/09/10 04:58 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I dont know Cab, i didn't realise there was more than one.
Thanks for the info.
Mick
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663850
04/10/10 07:59 AM
04/10/10 07:59 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Crane dual springs, eight years of street and strip. bullet proof.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663851
04/10/10 09:17 AM
04/10/10 09:17 AM
NC
440Jim Offline
440Jim  Offline
NC
What pressures do your springs measure? I have seen people report significantly different values over the years. So, maybe Edelbrock changed springs at some point.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: 440Jim] #663852
04/10/10 03:12 PM
04/10/10 03:12 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I have nothing to measure them pressure wise but the eddy site claims they are good up to .600 lift, so rather than wipe the cam i'll try them and if they dont work out, i'll get my wallet out again.
Mick
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: deaks] #663853
04/11/10 12:47 PM
04/11/10 12:47 PM
NC
440Jim Offline
440Jim  Offline
NC
I think if you took them to a shop to measure the Edelbrock RPM valve spring pressures, they would be around 120 seat (1.88). I can't guess at the spring rate and open pressure.
But like I said, many reported differences over the years. The danger with too little spring pressure is valve float and the resulting valve train damage. It could be mild, or could ruin the valve seat sealing, bend pushrods, break rockers, not to mention weaken the springs. If a retainer or locks(keepers) let go, it could swallow a valve. I would be careful.
Re: SPRING PRESSURE ON MOPAR .590 CAM [Re: 440Jim] #663854
04/11/10 01:40 PM
04/11/10 01:40 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
Thanks Jim
I still have to buy pushrods, new slicks and a converter yet, so money is getting a little tight.
I will try it with the 6500 chip first, shift at 6200.
If work picks up a little more, then i'll buy the springs sooner.
Mick
