Re: SPRING PRESSURE ON MOPAR .590 CAM
[Re: deaks]
#663836
04/07/10 06:56 PM
04/07/10 06:56 PM
Posts: 5,080 organ
maximum entropy
organ
that would be too much with the inners imo. that cam is next on my list, and i'm going to run it with a fresh set of rpm springs. i've had very good luck with those springs on similar cams.
[Re: deaks]
#663838
04/07/10 09:27 PM
04/07/10 09:27 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I ran the Isky 8005a springs with the 590 cam with good luck, also used 1.6 rockers.
[Re: deaks]
#663841
04/08/10 08:40 PM
04/08/10 08:40 PM
Posts: 16,925 NC
440Jim
NC
I've just checked the springs they are 190 seat, stock eddy valves, isky 1.5 solid rockers. I dont really want to buy another set as i also need new push rods, a converter and a new set of slicks and the money is running out. I've got a spare set of brand new stock eddy springs, they claim they are good to .600 lift on their website. Jim I will shift at 6200 and maybe 6700 or so through the 1/4 mile. prosport I cant find them on isky's website, do you know what spring pressure they are. Mick 4.56 gears and 31" slicks. Mick
IMO, the springs you have will risk wiping the solid lifter cam. With only 6700, you might be fine with 340 open, but I still like 130-140 seat.
[Re: ProSport]
#663842
04/08/10 09:03 PM
04/08/10 09:03 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
thats what i use. i think they are about 400lbs open .
[Re: 493_DART]
#663843
04/08/10 10:29 PM
04/08/10 10:29 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
I have them also. But, I dont think they are near 400 open, more like 330-350.
Looks like they are 135 on the seat at 1.875.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#663844
04/09/10 11:18 AM
04/09/10 11:18 AM
Posts: 16,925 NC
440Jim
NC
From Isky web site: http://www.iskycams.com/springbook.pdf125 at 1.900" 145 at 1.850" So at 1.88" that would be about 133 lbs seat And at 0.590" lift from 1.88, ie 1.29" open 365 at 1.300" 385 at 1.250" So at 1.29" that would be about 361 lbs open
[Re: deaks]
#663851
04/10/10 09:17 AM
04/10/10 09:17 AM
Posts: 16,925 NC
440Jim
NC
I'm going to try the edelbrock singles,
What pressures do your springs measure? I have seen people report significantly different values over the years. So, maybe Edelbrock changed springs at some point.
