68 charger vacuum diagram #663785
04/07/10 04:34 PM
04/07/10 04:34 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
I am getting ready to attach the vacuum lines for the headlights and would like to see the vacuum diagram to how the line go in. Does anyone have such a critter that could help me?
Re: 68 charger vacuum diagram [Re: TrueTripleX] #663786
04/07/10 05:49 PM
04/07/10 05:49 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Do you have your old vacuum hose assembly. If you do it should be easy for you to hook up. I just hooked mine up and when the lights didn't work properly I just switched the lines around at the headlight harness until it worked. The factory service manual diagram seems very vague to me. Hardest part is hooking up the right lines to the headlight switch.
Re: 68 charger vacuum diagram [Re: rapom] #663787
04/07/10 07:57 PM
04/07/10 07:57 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
This help from the FSM?
1MYTGTX
